mesh paint
Mesh Paint v0.95
Updated September 2012 with straight/curved line drawing. Mesh Paint lets you paint
meshes or mesh instances interactively on the surface of another mesh. Not only for
placing rows of bolts but with every thinkable placement option like follow stroke,
stack clones, adjustable spacing, delete overlapping, alignment, randomization, size
falloff and mouse position interpolation (for evenly-spaced placement even when painting
quickly).
To-be-placed objects are organized in a list with the option of randomizing though the list, or cycling through the list while painting. There's also a »drop« mode for placing indivdual objects more precisely (like a simpler version of Piotrek's QuickPrimive tool).
For more information, visit the si-community thread linked below. Videos available: Introduction, and added features in v0.91 & v0.93. The roses in the thumbnail have been created with a combination of follow stroke/stack clones/ramp scale, moving the mouse around in little circles. For regular spaced placement like the zipper in the thumbnail, turn off the »delete overlapping« option. Source code available here (Check the thread for a newer version of this, too).
local backup: meshpaint_095.xsiaddon
Re: mesh paint
wow! thanks for your effort, brilliant!
Re: mesh paint
You mentioned the duplicate function is slow in Softimage
(I experienced this before - it is MEGA slow), would it be faster to decompose the model you want to duplicate using a CGeometryAccessor,
insert empty meshes into the scene and use a CMeshbuilder to rebuild the mesh?
I heard the CMeshbuilder is awesomely fast, but I haven't tried yet.
Re: mesh paint
This would be probably faster, but the result would not be instance model but new mesh. And you still have to copy all the properties, clusters and so on.ace63 wrote:You mentioned the duplicate function is slow in Softimage
Problem is there is no function or whatever for duplication, only a command call (which takes approx 25ms per call)
meshPaint v0.93
meshPaint v0.93:
+line drawing
+faster mouse interpolation
Just thought I should post this here, hope it's okay with you Piotrek? How's your arm anyways?
May I suggest a feature, an arc or curve drawing?
Something like this, perhaps combine SHIFT+CTRL+ click or SHIFT+right click to do an operation?
After initial straight line drag, you can change the position of the (invisible)control points with cursor.
Re: meshPaint v0.93
thanks for suggestion. Ive implemented it and now it's easy to do strokes on curved surfaces with just two mouse clicks. Now there's bigger task, arc length parametrization, for equal clone spacing, better follow stroke and non-linear mouse interpolation.Memag wrote:
Re: meshPaint v0.93
- eternal art
Re: mesh paint
GOOD but can you make the painting object be Animable or keyframable?
TNKS
TNKS
Re: mesh paint
Another suggestion,
if there is a way to create a polygon ribbon along the line (straight,freehand,arc,curve) and make polygons weld if within certain distance
this would also make a kick ass re-topology tool, as if it's not kick ass already.
Re: mesh paint
Great stuff!
Memag: yes, that retopology-idea came into my head too when I saw the last bit of the video, now that would be exiting. Would it be at all doable within this plugin or does it need too much re-working?
Anyway, I'm eagerly waiting for this one.
You already can? (see page 1)bodoquedoc wrote:GOOD but can you make the painting object be Animable or keyframable?
TNKS
- Daniel Brassard
- Contact:
Re: mesh paint
I agree with you Memag althought maybe have it separate from mesh paint (retopo tool). I would suggest quad or triangle fans/strips with auto welding as you said. The problem will be n-gons at intersections but I can deal with that if the tool save me time to create the polygon strips/ribbons/fans.Is there a way to create a polygon ribbon along the line (straight,freehand,arc,curve) and make polygons weld if within certain distance
I envy your programming skills Origin. Thanks for this great tool.
Dan
Re: mesh paint
This is awesome!!!! I have a project just waiting for this tool
Piotrek, you're a superhero!
Re: mesh paint
Yes polygon modelling just doesnt fit into this tool really. Meanwhile Ive replaced vimeo clip with new stuff showing bezier line drawing.
Re: mesh paint
oh my! this is good stuff Piotrek. Also recently was watching this brave effort from a 16 year old I believe who just won his funding from crowdsourcing http://spartaproject.com/ and realised we could pretty much do most of it in ICE already - apart from the live brush painting. So I was wondering if we could use meshpaint as it stands to paint new particle points onto a cache file, these points would persist in space for an X amount of time and could be a force or influence to push / pull / converge /delete / scale / whatever the cache (depending on the brush size strength etc) that way the cache files moving over these points in space would be influenced as well - so you would not have to paint over EVERY frame see this demo of converge brush for example.
Re: mesh paint
a retopo tool is totally doable with the new custom tool sdk. i was thinking on the lines of the bsurfaces...
http://www.bsurfaces.info/
and silo's topo pen
s
and silo's topo pen
s
Users browsing this forum: No registered users and 74 guests
