You can store it in https://www.dropbox.com to share it ?
Sycles 2.1.3
- wireframex
- wireframex
Hi shekn,
Do you think to update HDRMaster soon ?
Phil
Phil
Thank you ..
Ok.
You can find the two "compounds" here:
https://www.taobargraphics.com/download
Right click on the button and "save link as..."
The new site is in progress, as soon as I have some time to complete it...
About HDRMaster. I think about it, but if make update, then it should fix some other problems. For example, when it fills the library with hdr maps, then it spams jpg-s to the directory with hdr files. It's not ok. It will be better to store these secondary images in different directory or may be even in the database. Also it will be helpful to add support of the other renderers: MentalRay, Arnold or my other integrations (ospRay and LuxCore). It's possible, but requires some time.
- wireframex
Thanksavalon_70 wrote: ↑06 Feb 2023, 02:51
EDIT : Can't download it --> I tried with Opera and Edge Browser without any success because of security problem
- wireframex
Ok don't worryShekn wrote: ↑06 Feb 2023, 14:48 About HDRMaster. I think about it, but if make update, then it should fix some other problems. For example, when it fills the library with hdr maps, then it spams jpg-s to the directory with hdr files. It's not ok. It will be better to store these secondary images in different directory or may be even in the database. Also it will be helpful to add support of the other renderers: MentalRay, Arnold or my other integrations (ospRay and LuxCore). It's possible, but requires some time.
It will be ready when it will be ready
Log Statistics won't log real object name as before?
// Geometry:
// Total memory: 5.08M (5,326,626)
// mesh 1.85M (1,935,408)
// mesh 496.20K (508,109)
// Geometry:
// Total memory: 5.08M (5,326,549)
// polymsh_detached1 1.85M (1,935,408)
// di 496.20K (508,109)
Try here:wireframex wrote: ↑06 Feb 2023, 17:05 EDIT : Can't download it --> I tried with Opera and Edge Browser without any success because of security problem
https://www.dropbox.com/s/h3b4vrunmtty2 ... 2.zip?dl=0
About logging mesh names. You are right, I will fix it in the next update.
- wireframex
Far betteravalon_70 wrote: ↑08 Feb 2023, 13:00 Try here:
After a long time I have to do a job that includes a render. I'm trying to use cycles and I noticed a few problems:
The first is the disappearance of the tiles in the options (blender 3.4 has them), and every test I have to wait for it to complete the whole frame.
The ideal is that they existed and started from the center in a spiral, but I don't know if this is feasible.
Second problem, the render must perhaps be very large in size (it will have to be printed), and doing a quick test up to about 8000px it works, then it crashes (I have a GTX 1070 with 8gb of ram), it could also be a settings problem that I do not know.
These are two slightly different issues. Tiling rendering option is hidden in UI of the Sycles, because there are some problems with it. I can not properly setup this mode. I set all parameters in the same way as in Blender sources, but my render is crashes. So, it requires more investigations. In theory this tiling mode should help to render big images.
But, I tried to render 16k width image in built-in MentalRay, ant it crashed. I think that the reason not on the render engine, but in Softimage. It allocates the frame buffer for output to the screen, and if it overflow the gpu memory, then it crashes. All successfully rendered in the batch mode. MenalRay image with 16k output result and also Sycles image with the same size. In batch mode all works with cpu or gpu render devices.
Okay, thanks for the reply.Shekn wrote: ↑19 Feb 2023, 08:34 These are two slightly different issues. Tiling rendering option is hidden in UI of the Sycles, because there are some problems with it. I can not properly setup this mode. I set all parameters in the same way as in Blender sources, but my render is crashes. So, it requires more investigations. In theory this tiling mode should help to render big images.
Tile rendering is very convenient for scene setup, when there is a need to calibrate the various materials.
Ok for the batch render, I've used it a lot in the past, if I remember correctly I still have a tool that helps in its creation ( RenderQ if I remember correctly).
Im having constant crashes on rendering Strands. Just a simple basic emission > generate strand trails and render causes softimage to crash
anyone experienced this?
I checked, and for me strands and, in particular, strand trails are working without any errors.
