Sycles 2.1.3
- wireframex
Great
Very small update with the fix of the very stupid bug in material previews: https://github.com/ssoftadd/SSoftAdd.gi ... 1.xsiaddon
- wireframex
Thanks man
Excellent!
And thanks for fixing the problem with GES import/export not installing on Blender 2.9x, as mentioned on GitHub!
Thanks! Will give this a try soon.
hello, i have a problem with the latest addon, there isnt anymore the option to select GPU on any render option panel in scycles now, am i the only one?
also the cpu render usage never goes above 50% during heavy high sample renders, while before i had 100% fully utilization, something is off
- wireframex
Hey Maximus,Maximus wrote: ↑06 Sep 2021, 10:41 hello, i have a problem with the latest addon, there isnt anymore the option to select GPU on any render option panel in scycles now, am i the only one?
Just create a new scene with a null
then File/merge your scene with it --> it will works
Save your scene and erase the null
Phil
If you see only CPU device in Performance - Devices List, then it means that system can not find correct devices of other types. In Sycles\Application\Plugins\lib folder there are severel *.cubin files. The system use it to recognize gpus. If these files are not compatible with gpu, then it can not be founded. I dont't know why it happens and how to fix it. You may try to get these files from different versions of the Blender distributive, but the result is not predicted. With some files the system can recognize device, but the render result may differ from cpu tasks or even have artifacts.
About cpu load. In Sycels render settings in Performance tab there is a paramter "Thread Mode". When it set to "Auto-detect", then the renderer use all threads of the cpu. But if it set to "Fixed", then it's possible to set explicit number of cores, which will be used for rendering. May be you activate this option?
- wireframex
I have the same Maximus problem and the only solution you gave before was the null tip and it works for me
Wanted to try the new version, but I now get a red triangle in the Plug-in Manager for all versions (1_10_1, 1_11 and 1_11_1).
So I guess Softimage finally has stopped working after the recent Windows Update...
Version 1_10_1 did work in the past, but now has stopped working as well...
Update: 1_9_1 does still work...
- sycles_1_11_1.png (6.72 KiB) Viewed 3402 times
Try to uninstall all vc-distributives from the system. May be this will help, because the last version of the Sycles 1.11.1 contains all necessary files in the addon package.
Sadly that won't be an option as that would inevitably break other important software...
You don't have a version handy without the built-in dependencies?
Of course, you can delete *.dll files from the Sycles addon directory. You need only the following files: cyclesPrimitives, cyclesRenderer, SyclesICENodes (these files contains actual addon functionality) and necessary dependencies for it: OpenColorIO, openvdb, tbb and yaml-cpp.
May be you have installed some other addon, which conflict with the Sycles? It's potentially possible.
so yeah i tested this engine quite a lot lately, cranked the sh*t out of it
here is a 44 mins render with insane samples and light bounce.
cpu amd 5950x and 2x 1080 nvidia
Users browsing this forum: No registered users and 74 guests
