Hi! Justa a question: There is a way, or a plug in, that is able to select all the HARD EDGES (i mean the blue ones only) on a mesh?
I have seen some plug-ins, but they select edges only based on specific angle etc etc. Because if you work on IMMEDIATE mode, hard edges clusters are not visibile in mesh components.
If some one know something, thank a lot!
And thank you!!!!!!!!!!!!!!!!!!!!!
Select all the blue hard edges
Re: Select all the blue hard edges
It looks like when the cluster is gone, this blue edge information is cached somewhere but I don't think it's accessible (maybe using the API)
Checking the polygon angles is not enough but RcTools has an edge selection filter that checks if the normals of the edge are split. Maybe this will work for your case
Too gentle. I take explore RC tools immediately, thank!
All hard edges by default are also creased edges so you can select them through the selection filter.
mHardEdgeMarker also has a button to filter hard edges
Thank you, but i need to select all the blue edges not depending from angle , but all the blu edges averywhere. I already use mHardEdgeMarker and is not able to select the blue edges, it work with a angle treeshold. thank you very much any way!
mHardEdeMarker has a button to select hard edges and a button to select edges by angles. Unless it’s an old version.
Anyway, tru selecting by crease edges
apologize me, probably i'm not able to use it, now i try again, forgive my bad ability.
Yeah! the filter creases work! YOu are great! i never used this option!!!!!!!!!! Fantastic!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Users browsing this forum: brandwatch [Bot] and 45 guests
