Arnold to go rental-only
Re: Arnold to go rental-only
Screw brute-force CPU path-tracing pop-culture! Point-clouds, voxel cone tracing, >1024 sampling - rock'n'roll!
(Quoted from here)A U-turn on Autodesk’s policy of last April
The move is, however, a fairly rapid reversal of the company’s policy on acquiring Solid Angle last April.
At the time, Autodesk industry manager Maurice Patel told CG Channel: “The one thing I will stress is that we’re not going to discontinue perpetual licences for rendering.”
“[Arnold] is a very different business model [to our other software, and] through the nature of how it supports other products, it just doesn’t make sense to do that.”
“We know that many of the customers [who use other] 3D products don’t necessarily want to move to subscription. We’re not going to force [other companies’] subscription agendas.”
Try Redshift and let them with Arnold.
you won't regret
you won't regret
Nice find, Hirazi ;) Once and for all, everybody by now should know, you can´t believe a single word out of the mouth of an AD-guy. Not that they are liars by intent! I think, that they truly believe in what they say. But in the end, it is not worth the breath, because the evil greed will break its way...
cheers,
oli
cheers,
oli
http://www.pixelpanic.de
"The future of Softimage is bright"
Installed the latest version of Redshift, and converted all shading from an old archviz scene.julius wrote:Try Redshift and let them with Arnold.
you won't regret
This one has gone through MR, VRay, Arnold and now Redshift, and is a pretty nice testscene for interior lighting.
Despite me not knowing yet what to set correctly for all the sample values, it renders (GI/Irradiance) pretty quickly.
Appr. 14 min. for a 1500x1000px, 10 portal lights and a HDR.
I'm reading up on sampling and such, so I'm sure I can shave off some amount of rendertime when I got the sampling better set up for the scene.
It probably take some time to get used to all the shader and sampling settings, compared to Arnold. It feels like I'm back at MR for some things LOL!
But for a first run it's not bad ;)
original resolution
And it's always good to have another renderer (or two) in your arsenal, not just because AD is messing it up for users once again.... ;)
- MauricioPC
Nice test Rork!
As for Redshift tutorials, I've been watching these:
https://www.youtube.com/playlist?list=P ... MNUeLPJ3z2
https://www.youtube.com/playlist?list=P ... q73COwLx1s
Thanks for the links, I found these as well while browsing YT. The Maya series is quite useful.
Another quick test, appr. 15 minutes rendertime:
original resolution
original resolution
Another great feature of Redshift is that you can cut your render times by adding more/better gpu's. I've found a linear acceleration up to 3 cards.
Nice !
I'm working with redshift for nearly two years now. It's a game changer : impossible to go back to any renderer now. The speed is crazy, and if you are used to MR or Vray, transition is very easy.
I've been fiddling with RS a bit more, and switched for these interior scenes back to Irr. Cache/Irr. Point Cache. This brought the quality/look in the same range as Brute Force/Irr. Point Cache, but brought the rendertime back below 10 minutes.And this included the caches creation which took almost 5 min. to build.julius wrote:Nice !
If I use the cache for a re-render, the frame takes appr. 4:30 min. to render.
It almost makes no sense to use Brute Force GI for interior scenes with RS..... ;)
Still find the sampling methods a bit tedious after years of Arnold, but I can adapt
p.s. The interview video above: bla bla bla bla bla.......
- MauricioPC
Yeah, but at the least he tried and he was able to bring someone from Autodesk to talk. I like Greg, looks like a good guy.Rork wrote:p.s. The interview video above: bla bla bla bla bla.......
At least it's more obvious what to expect from Autodesk now.
True, he tried.
But AD does what AD does, only keep it's stockholders happy :\
- MauricioPC
Yeah, true to that.
It's a shame that the market is still heavily Autodesk depended. Hopefully that will change in the future. Blender is starting to pose as an alternative more and more.
Nice!
I have seen something on this ?over a year? ago, good to see this is still going. Looks terrific!
And on a side note: I grew up with this comic, so it's all very familiar to me
