Wanted: SSS Skin Tutorial
Links and discussions concerning tutorials
Post by Hirazi Blue » 08 Mar 2016, 13:31
I am looking for a good thorough explanation of how to set up a SSS Skin shader in MR.
Using the default values just looks horrible, but I have no idea how to tweak all the parameters
to get to a more or less convincing result...
Rork
Re: Wanted: SSS Skin Tutorial
Post by Rork » 10 Mar 2016, 11:38
What about the MR docs that come with SI?
I can recall a pretty extensive explanation on the skin shader and the textures that will go along with it.
There was also a PDF about skin shading, not sure if that was in the docs as well.
Sorry to be vague, I don't have SI running atm.
anhungxadieu
Skype: nguyenvuducthuy
Post by anhungxadieu » 11 Mar 2016, 14:29
well, i see fxphd have one call "Production Rendering Techniques with Mental Ray"
this course instructor very well explain sss skin in mr, unfortunately he use 3dsmax, but i think it should be the same in xsi :)
https://www.fxphd.com/fxphd/courseDetai ... Course=202
Rork
Post by Rork » 12 Mar 2016, 15:28
Yes, "Zap" knows his stuff about MR :-)
Unfortunately you must have a paid account to access those tutorials.
Good find though, completely forgot about that one ;-)
Post by rray » 12 Mar 2016, 15:50
Rork wrote:What about the MR docs that come with SI?
It is, that one, 12 years old but still pretty much current considering MR's dev progress 8-x
file:///C:/Program Files/Autodesk/Softimage 2015 R2-SP2/Doc/mental_ray/tutorials/fast_sss_tutorial.pdf
-rr
wesserbro
Post by wesserbro » 12 Mar 2016, 16:49
I had several attempts of creating skin with mental ray fastSSS, pretty much got decent results, but each time it was like a first time, so thats not really a straight-forward process by any stretch. From what i can recall now you should use 2.2 gamma and play with layer compositing options. Seems i even ended up compositing sss layers in post, so get ready to not get good results out of the mr box )
And one more note: skin shading is much more complex than any tutorial existing by now shows you.
Post by Hirazi Blue » 13 Mar 2016, 16:09
Thank you, guys!
wesserbro wrote:And one more note: skin shading is much more complex than any tutorial existing by now shows you.
I feared as much... 8-}
sirdavid32
Post by sirdavid32 » 20 Mar 2016, 04:10
Ignite a light, place the camera against the light (like recieving a flare) and place the mesh in front of it.
Use fast SSS shader. You need to write a lightmap (in case you don´t have one, you still use mental ray but tweaked
versions of SSS / search-download from web) and then SWITCH ON "shadows" on light (any kind of light).
Subsurface parameter is "specular". Play with base and measure in mm ; how light will produce shadows inside of the mesh (with the sss shader).
This way you´ll apreciate the effect.
DT (digital tutors) have a 2007 xsi training series about this.
