OpenVDB to Softimage
OpenVDB ICEAuthor: Oleg Bliznuk
This is a Softimage ICE integration of the OpenVDB suite, Dreamworks Animation's volumetrics toolset which has been built around a new data structure for efficient storage and manipulation of big volumes. See openvdb_dreamworks.pdf for slides of a OpenVDB feature presentation.
Oleg Bliznuk, author of Exocortex's Implosia FX and Explosia FX has created this ICE adapter. His fluid simulator »Explosia FX« (free as a noncommercial version) can be used to create VDB files. OpenVDB ICE covers the essential features of the OpenVDB suite:
For feedback and questions, visit the si-community thread. There's also some info there on how to interoperate with emFluid. Here is a demo video by the author and another video from the thread, created by Rob Chapman using only OpenVDB ICE nodes and rendered using the included openVDB arnold shaders. Requirements: Microsoft Visual C++ 2012 Redistributable Package (x64)
sant0s
Re: OpenVDB to Softimage
Post by sant0s » 07 Jun 2015, 10:31
hmm, should actually work.
maybe you pick the wrong channel?
klebedaja
Skype: klebedaja
Post by klebedaja » 07 Jun 2015, 11:02
I don't think so.
If somebody can give it a shot here is sample vdb. It's far, far away from centre, just so you know...
This vdb contains only one container.
I can post vdb with multiple containers later.
stinger_00.0025.rar
(20.62 KiB) Downloaded 227 times
Bullit
Post by Bullit » 22 Jun 2015, 02:02
Is it possible to use OpenVDB for Softimage to convert Realflow bin files to OpenVDB? also other particle files that Softimage can read?
sant0s
Post by sant0s » 22 Jun 2015, 10:00
you could read the points from the .bin with emFluid5 and save it out as .vdb.
or you try olegs .vdb plugin for saving out pointcloud as .vdb. that works for sure - but dont know, if that file will work with a new openVDB version.
Bullit
Post by Bullit » 22 Jun 2015, 15:44
Thanks. You mean the new version is the OpenVDB 3.0?
sant0s
Post by sant0s » 22 Jun 2015, 15:51
yes.
But I have some old vdb files here that work with new version of SitoA, guess it should run fine.
oleg has an example how to create an .vdb from pointcloud in the openvdb thread here.
if you get it to run, let me now :)
Bullit
Post by Bullit » 22 Jun 2015, 16:21
Ok, i will.
sant0s
Post by sant0s » 22 Jun 2015, 16:51
just tried it, works so far with sitoa!
thats the setup I mentioned.
http://www.si-community.com/community/download/file.php?id=3364&mode=view
Bullit
Post by Bullit » 22 Jun 2015, 17:09
Yes. But doesn't work with realflow point clouds, if i connect a basic emission from a null i get all nodes okay. I connect an RF point cloud i get all red.
This is the RF point cloud, maybe it misses some information
sant0s
Post by sant0s » 22 Jun 2015, 18:16
try adding the self.size attribute below the Set Particle Position node.
Bullit
Post by Bullit » 22 Jun 2015, 18:38
Yes, nothing red now. Will check if i can save as vdb's.
Edit:
It works, the VDB_BaseVolumeContainer partciles match those in Realflow ICE tree. To save as sequence i had to put in IO node frame the current time. To read i let it there too. Below the ICE tree.
Edit 2: For comparison the bin files are 570 mb, the VDB file is 100 mb
sant0s
Post by sant0s » 22 Jun 2015, 21:13
nice, thx for the update!
did you manage to render it?
i did try to render the .vdb file I got from the .bin and get a solid volume thats cubic. though its the particle size or somethin.
also it the rendertime in comparsion to other .vdb files is very slow. but that happens only with the converted .bin files, everythin else is rendering fast!
Bullit
Post by Bullit » 22 Jun 2015, 23:14
What render you are on? Arnold? i have yet to get the trial.
sant0s
Post by sant0s » 23 Jun 2015, 01:43
yes, Arnold.
Bullit
Post by Bullit » 23 Jun 2015, 21:30
Did you tried the dll shaders?
sant0s
Post by sant0s » 23 Jun 2015, 21:35
actually it works with all other .vdb files.
just the one I exported from the .bin.
Ill try again. DLL? need to check that :)
