This is my personal migration software ;)
Re: This is my personal migration software ;)
Thanks Rray
installed succesfully!!
How to choose the splash screen once your app is installed?
Can your "Softimage Survival pack" add new features and bug fixes to Softimage 2015??
2015 version will be added if it's got the ugly icons too (which seems likely). [now added..] bug fixes: only a few would be possible. the rest would require source code access to even have a chance. added features would be possible through the usual plugins system.. but no concrete plans so far
splash screens can't be chosen there's only a different one for each SI version.
Reason: 2015
Reason: 2015
What about the so called ICE attribute editor that is said will came with 2015, anyone took a peek at it?
I updated the "Softimage Survival Pack" yesterday for Version 2015 so you can have the (imho) better looking icons and the splash screen for that one too.
Also packed two handy little features in there (Multi selection of objects from ICE "get data" nodes + adding a "custom ICE operator" to several objects with one click)
(see a few posts before for the link)
Hey, have instaled in the new 2015 version.
Very cool indeed! Thank you very much!
The Future is Gloomy!
I like the Softimage 2015 icons and splash screen from Autodesk, actually ;)
what do the replacement look like? I don't want to run an arbitrary .exe ...
it's the v7 splash
If you use Resource Hacker you can replace the bitmaps manually. I used RH for the first time after it was mentioned in this thread and it was really easy to use.luceric wrote:I like the Softimage 2015 icons and splash screen from Autodesk, actually ;)
Tom Kleinenberg - Previz/Layout Artist/Generalist. Any views expressed are my own.
here's a preview of the graphics i'll upload the ico file later
I think that old application icon (toolbar.gif) looks terrible.. AFAIK it's the icon from XSI 7.5 or 2010 at autodesk, not avid. the avid days one was square with rounded corners, this one is like a plastic chocolate bar rectangle - it's the 3ds max/discreet look.
the old softimage splash screen is ok, but I think the new procedural splash Autodesk have made is really gorgeous. the icon has also been fixed to blend in better
I am finally Installing the 2015 Ultimate suite so will check it out. BTW Luceric; I saw some new things being installed. AUtodesk Recap and Autodesk Suite Exclusives. Can you give me more info on what they are/ do.
