I was given a big mess of a building, it is a boxy model with almost no curve form, but it is modeling disaster with hundreds of intersecting polygons. So i need to remake it to make it much lighter. What should be the best approach?
Get a grid and move/add points with snap?
Trace the relevant building edges with curves?
Extract the relevant edges? since many belong to intersecting poligons might not be a good idea.
Any other idea, or tutorial?
Boxy retopology best practices?
Re: Boxy retopology best practices?
-Get/Primitive/Polygon Mesh/Empty
-Turn on snap to point.
-Use the Create Polygon Tool to create a new mesh along the lines of the old one but missing out the bad modelling.
It's tedious but you will be sure it's done correctly.
Or buy Topogun
Or buy Topogun
Thanks, that is what i ended up doing.
I wonder if a sort of shrinkwarp would work too, maybe it needs a too detailed mesh.
- KLONOA WORKS
for topology I follow this video its about shrink wrap. hopefully this is what you need.
Since it was a boxy model I wouldv started out with a box/cube hehe. middle mouse click on edges with the split edge tool a few hundred times (throwing in the odd extrusion) and job done ?
I fixed the thing from the model itself.
