i'm on some wav file driven animation, id like the script can loop for each frame.
i mean keep looping iterate by frame.
search for help file, no idea. so is that can be done? i dont think a script operate can do that
thank you
if script can run for each frame?
Re: if script can run for each frame?
You can. You have to find the Play Control object and set it's current frame parameter to the frame you want in a loop. Docs illustrate how to manipulate the play control quite well.
since now my script can read data from wav file to array
thank you eric, you save me again
