Resourcedump
Get Closest Filtered pointsAuthor: Paul Smith
Disclaimer: This is from the resourcedump thread on si-community.com so »some restrictions may apply« (but usually don't)
A compound that gets ONLY the closest points in the current pointcloud/geometry that have a »true« boolean. It's much much faster than rifling through arrays. Hopefully someone will find this useful. It works by temporarily moving the filtered points up and away on the Y axis, then the remaining points look in the area where the filtered ones got moved to. Then filtered ones are moved back to their original location. The temporary moving of them is nothing to be concerned about because you wont see it and it doesnt affect simulation.
local backup: Get closest filtered points.xsicompound
caledonian_tartan
Re: Resourcedump
Post by caledonian_tartan » 17 Sep 2013, 13:46
a little test on terraforming.
uses high quality viewport.
feel free to improve or create presets!
Scene
SI 2015 @ WIN7-64
Bullit
Re: Resourcedump
Post by Bullit » 17 Sep 2013, 22:16
Looks good. Is the scene only for 2014, i see your signature?
caledonian_tartan
Re: Resourcedump
Post by caledonian_tartan » 18 Sep 2013, 09:22
yes
but i now included the shader and ice compound into the zip file. so you should be able to use it in older versions.
SI 2015 @ WIN7-64
caledonian_tartan
Re: Resourcedump
Post by caledonian_tartan » 24 Sep 2013, 13:39
a small modification of the "Bezier Movement along Surfaces" compound. unfortunately i can't remember who was the author of this source...
anyway, you can now use the new compound to create strands by/through many surfaces.
Cable through Surfaces.zip
(26.04 KiB) Downloaded 435 times
SI 2015 @ WIN7-64
Bullit
Re: Resourcedump
Post by Bullit » 24 Sep 2013, 15:27
Thanks, also for the non 2014 version.
Re: Resourcedump
Post by rray » 05 Oct 2013, 23:01
Nice!! keep them coming!
forton
spherize
Post by forton » 13 Nov 2013, 12:29
Deformer that takes a null or group of nulls and pushes the objects points outside the nulls, nulls can also be rotated and scaled, can be useful for "muscle type" deformation or correcting volumes in characters etc.
Scenes.zip
(129.33 KiB) Downloaded 326 times
caledonian_tartan
Re: Resourcedump
Post by caledonian_tartan » 11 Dec 2013, 15:19
hello
i'm trying to get used to arrays. so after playing around a bit i got a "4 point 3d corner pin".
4 Point Corner Pin.xsicompound
(55.04 KiB) Downloaded 302 times
the downside is:
- only works for grids.
- you need to match the Resolution of the Grid and ICE compound manually. (is it really impossible to get or set the resolution from the geometry operator? i guess so...)
SI 2015 @ WIN7-64
mattmos
Re: Resourcedump
Post by mattmos » 11 Dec 2013, 20:02
You can't just drag the green widget in to the ice tree? It works for me here, can get .subdivu and .subdivv data.
Thanks for sharing btw!
Edit: I'm using 2014sp2
caledonian_tartan
Re: Resourcedump
Post by caledonian_tartan » 12 Dec 2013, 08:31
that's great news!
i remember i did so too in the past. but i doesn't let me now... (SI2014 SP1)
good to know, thank you!
EDIT: "this.geom.subdivu"/"this.geom.subdivv" is the way to go with a get data!
SI 2015 @ WIN7-64
gustavoeb
Skype: gustavoboehs
shallow water simulation coupled with lagoa multiphysics
Post by gustavoeb » 21 Dec 2013, 02:20
For those in the need to simulate SIMPLE water interactions FAST this is a shallow (2d) water simulator coupled with Lagoa, so it does not look toooooo cheap. It cant do curls and rolling waves, but it will spit some Lagoa particles for your viewing pleasure :D
It served quite well on a little student short, so maybe it can help others. I would love to keep working in it but no time for it, so here it goes:
https://dl.dropboxusercontent.com/u/39280733/mFlow.scn
KEEP IN MIND:
1. Anything that says "Energy Conservation" is actually just a multiplier of some energy transport. So it is like other multipliers, but, if you go over 1 energy will increase instead of dissipate causing a chain reaction that can blow up the entire matrix. So use it carefully. Turn 2-way coupling off if you really need to cheat physics.
2. Use it as is, or hack it at will... I cant support it :p
PS:
There are other things that could be done to it. It could be made more physically correct. Motion transport could have more meaningful parameters like say, viscosity. Also maybe someone could implement a bottom attribute so we could calculate the actual volume and preserve it accordingly... one can dream :ymdaydream:
Gustavo Eggert Boehs
Re: Resourcedump
Post by rray » 14 Jan 2014, 17:03
Thanks all for keeping it up!
>>>>>>> This is a patch for a factory file - use at your own risk!
This one allows custom ICE operators (those Peferences->Custom->ICEOperators) to be applied on each selected item instead of on just one selected item (default behavior)
2014SP1
C:\Program Files\Autodesk\Softimage 2014 SP1\Addons\ICEUserTools\Application\Plugins\ICEUserTools.vbs
(line 596)
function OperatorClicked(in_ctxt)
	on error resume next
	oString = in_ctxt.source
	for each o in selection
		applyICEOp oString, o
	next
end function
caledonian_tartan
Re: Resourcedump
Post by caledonian_tartan » 14 Jan 2014, 17:28
sounds cool! thanks rray.
can you give an example of when or why to use those "ICEOperators" from preferences?
SI 2015 @ WIN7-64
Re: Resourcedump
Post by rray » 14 Jan 2014, 18:01
It's just a convenience feature. When you have an ICE tree that you want to apply to another object, just compound it up, register it by exporting, and enter the compound name in the preferences. You can just select an object, click the menu and the compound get applied to the object.
Otherwise you'd have to go through the whole create new ICE tree--->drag an drop node-->connect to execute port, deal.
This is all built in, what the patch does is just allow to apply the compound to several objects at once using the same menu.
Tekano
Re: Resourcedump
Post by Tekano » 16 Apr 2014, 01:46
aaand it took a while to find this thread. it was in plugins! anyway , always nice to resurect it again, here is a quick setup demo scene example of rigid body (vorlex) simulated with verlet for some ICE on ICE interplay.
from a request on the mailing list.
scene file attached v2013
Deformation_Verlet_Cloth_net_vorlex_ball_rc.rar
its a .rar archive to squeeze it in
(230.4 KiB) Downloaded 382 times
Bullit
Re: Resourcedump
Post by Bullit » 17 Apr 2014, 01:19
That looks very good.
