Sun position plugin
Re: Sun position plugin
Bravo to make this available. Thank you !
Thanks, Face, for the great addon!
I'm too stupid to figure the basic setup, though. Could you please demonstrate the necessary steps?
Create a pointcloud, add a simulated ICE tree, add the "sun position frame" node, ok.
Now what? Do I need to add a point first? Nothing's happening when I move the time slider.
Thanks and best regards,
Eugen
Eugen
I will upload a simple test scene when i´m back from work, in about 10hrs ;)
face
face
Ok, here is a simple test scene which shows how to drive the position of a point light, with the calculated sun position from the plugin.
face
face
- SunPosition_Scene.zip
- For Softimage 2013
- (132.67 KiB) Downloaded 194 times
Thanks a lot, face! That will do... =]
Hi face,
a question: what's the correct way to rotate the north arrow (= the pointcloud) in the direction I need?
If I do so, there's an offset between the light and the coordinate generated by the sun position core.
Eugen
Eugen
You can simply change the north offset in the location compound to the location which you need.
An offset of 0 means, north is in +z. 90 means in -x, -90 in +x and +-180, north is in -z.
face
face
I see, thanks, face! Could have figured...
Users browsing this forum: No registered users and 94 guests
