aa_Ocean: Tessendorf Waves
aa Ocean Suite is a collection of Softimage ICE nodes and a mental ray shader that implements Jerry Tessendorf's paper on simulating ocean waves, which is currently the most widely used method for open water ocean surfacemodeling being used in the industry.
http://warpedspace.org/aa_ocean.html
Re: aa_Ocean: Tessendorf Waves
...it´s a great compound with very cool features an FAST ;)
Here is one of the test I´m doing with it...
http://www.pixelpanic.de/temp/ocean.mov
..the movement of the ton is given by some certain ICE operations and the usage of the unsupported kinematics...
cheers,
oliver
cheers,
oliver
- ocean.jpg (24.25 KiB) Viewed 19461 times
- farhaad_yousefi
owei wrote:...it´s a great compound with very cool features an FAST ;)
cheers,
oliver
awesome work by amaan akram..
owei, would you mind explaining how did you manage to get that ton floating to work? I am trying to achive similar effect but dont't know where to start. I am not a realistic effect although.
Thanks! The aaOcean 0.9a version is sweet indeed
Hi..!
It´s very simple. I´ve attached a compund to do this job. Just have a look inside.
You will have to connect a (water)surface, an overall positioner and a swimmer.
The compond looks at the points nearby the positioner and calculates an average of point positions and normals. These are given to the swimmer object. That´s it ;)
Of course you have to switch unsupported kinematics on..!
Hope this helps,
oliver
Hope this helps,
oliver
- swimmer.jpg (66.44 KiB) Viewed 19076 times
- Swimmer.rar
- (1.69 KiB) Downloaded 1142 times
Brilliant. I wish I could look inside this compound
hi oliver!
thank you very much!
btw, using a second swimmer compound with a camera and keeping the interest contrained to the first swimmer object will produce a very nice "man-over-board" feeling.
cheers
robert
@Victorcg: you can check out oliver's compound. it's not private... or did you mean amaan's wicked ocean-compound? ;-)
cheers
robert
@lenz
that´s nice..! And a good idea, too.. I´m happy ;)
@Victorcg
...jap, mine is not private..that´s true. The aa_Ocean-compound contains a custom node, as far as I know..never the less, this one IS private...
cheers,
oliver
@Victorcg
cheers,
oliver
Oliver!
That swimmer animation you rendered looks great! So I thought I'd give it ago. I just can't get my swimmer to move smoothly, it keeps rotating backwards and forwards erratically. What is the positioner? I have a null set as that, but what does it represent? Should it be parented to the swimmer? Anything I can do to smooth out this crazy rotation?
Burg
Burg
Hello everyone,
Sorry for the double-post from the xsilist--thought I'd post a quick update here too
I have updated the ocean plugin to version 1.5 This version is a complete re-write and is geared towards performance and workflow improvements. New features and improvements include
- 3 to 6 times faster than the last ICE version
- All ocean parameters are now animatable with little/no performance hit
- 3 new mental ray shaders that connect directly to ICE and render ocean data. New shaders for displacement, normal map shader (fixed from v0.9), foam and image-based vector displacement
- All shaders do render-time catmul-rom interpolation to produce smooth surfaces
- Ability to output EXR files via a renderfarm (EXR output is now done from shaders, and is still supported to allow renderers other than mental ray to render oceans)
- Ability to layer multiple ocean shaders on a surface to easily break up visible tiling. Each shader can either generate a high-resolution ocean based on ICE, or can be individually tweaked to produce variations
please note that this version is for XSI 2010 and beyond, and is not backwards compatible with v0.9a
As before, documentation and downloads at http://www.amaanakram.com/plugins/aaOce ... ocean.html
The download package now contains 2 sample scenes to show some sample rendering setups.
To run aaOcean Suite, you need to install the latest security patch from Microsoft for Visual Studio 2005 redistributable packges from
http://www.microsoft.com/downloads/deta ... laylang=en
Please do report any bug reports. Since this is a complete re-write, there must be some bugs lurking somewhere.
-amaan
-amaan
HI..!
@amaan
Great news..! Thanks for that..!!
@burg
Have you took a look into the compound..? There should be a "Direction to Rotation" node. There you will find an upvector. Fixing the axis should solve the problem I think..
cheers,
oliver
@amaan
@burg
cheers,
oliver
Thanks Oliver! It's still flicking from one to the other, regardless of the upvector. I'll have a look at it another time, thanks for helping.
This aa_Ocean is amazing stuff. I'm attempting to pull a boat through the aa_Ocean Water grid and get a deformation effect. I can get a deformation effect going but how do I get it to work in conjuction with the aa_Ocean compound? No matter where I put it on the port port or in a separate ICE tree above, the effects seem to be overidden by aa_Ocean. Anyone have ideas?
Thanks so much in advance
Burg
Burg
I've ran into the same problem. It seems the ocean node is doing something that overrides anything that comes after it in the chain. It would be awesome if you would be able to create wakes as well, but I think it will not work due to the rendering part of the setup?
you can combine aaOcean grids with just about anything provided the point count is the same. The latest aaOcean 1.5 outputs point positions, so you can then layer them on directly on to your grid. If not, you can always run aaOcean on one grid, run your boat wakes on another, and then switch-context to a third grid which adds point-positions from the other two grids together. I've used this method with v0.9 and it works just fine and speed is nice too.
yes, the current shaders will not be able to pull point positions from anything other than a tessendorf ocean sim. This is a current limitation, though all the code is set up to mix scalar/vector data from any other object -- I just haven't linked it up yet.
I'll disagree with myself slightly. The displacement shader is designed to work with a pure tessendorf mesh. The rest of the shaders can be layered on top of 3D geometry. So if your 3D geometry already has boat wakes on it, you could just layer on top a high-resolution ocean normals shader from aaocean.
If you want to do boat wakes, I am releasing an unsupported version of my Tessendorf iWave implementation (http://vimeo.com/7350049). This ICE plugin can be downloaded from
http://www.amaanakram.com/plugins/aaOce ... eWaves.zip
The zip file contains a Softimage 701+ addon and an example scene of how you can very easily mix tessendorf ocean sims with the iWave plugin.
This is unsupported because its based on a very weak numerical integration solution which is prone to explode and sometimes the values you enter in the sliders make no sense. I've added some multi threaded code to this to make it faster than the documented version. I hope you will find it useful.
