Hi, this is a quick take on Sascha Henrichs' procedural rock modeling workflow (http://vimeo.com/10163233)
features:
- 3 noise levels:
level 1: cellular (overall rock shape)
level 2: fractal (erosions)
level 3: turbulence (high frequency displacement)
- spatial UVs
- render tree rock shader compound
can be applied on empty polymeshes (cube primitive) or on a predefined volume mesh (check "Use Base Mesh" inside the compound)
can be used to generate lowpoly game assets (ao/normal maps) through ultimapper.
tip: if the mesh has interpenetrations at higher resolutions, try adding more lvl1 smooth.
2do: blended box maping to handle uv seams when using textures.
let me know about any suggestions.
Rock Generator
Rock Generator
AKA FC Rock. A procedural rock generator and an accompanying render tree compound
for high res bump details. Based on Sascha Henrichs' workflow as demonstrated here.
Noise types: level 1: cellular (overall rock shape) level 2: fractal (erosions) level 3: turbulence (high frequency displacement).
Demo video. More details available in the si-community thread.
local backup: FC Rock.zip
author site: http://iceduous.blogspot.com / download @ si-community thread
Rock Generator
- FC_Rock.xsirtcompound
- render tree shader compound
- (20.97 KiB) Downloaded 3288 times
- FC Rock.xsicompound
- ice compound
- (72.47 KiB) Downloaded 4044 times
Re: Rock Generator
Sweet compound!
Thank you.
Thank you.
Re: Rock Generator
What a gorgeous looking rocks! Thank you, Fabricio!
I'm a newbie to the modeling side of things, is there any way to bake highly tessellated polygon object into bump\normal\displacement maps? Thanks!
Re: Rock Generator
Sure! That's what ultimapper is for. Here's a step-by-step example:...is there any way to bake highly tessellated polygon object into bump\normal\displacement maps?
1- Create a basic rock. In this example I'm using an icosahedron as the base mesh to sculpt the overall volume of the rock. Apply fc_rock on top of that.
2- now duplicate your object, set different mesh resolutions for the low poly and hi poly models (I'm using low=0 and hi=7)
3- set up nice UVs to your object. try to put the seams at sharp angles, so that they are less noticeable. For this quick setup, I've used a basic spherical projection.
4- align both objects so that they are centered (in this case simply move to 0,0,0)
5- select the lowpoly mesh and apply a ultimapper property.
6- on the ultimapper ppg, pick the high res mesh and check what kind of map you want to export. Also, be careful when choosing the quality/resolution of your maps. Try to be reasonable because exporting times can go through roof here. Choose the directory where the maps will be saved, click "compute", then "generate".
7- lastly on the "Preview Shader Tree" ppg tab, click create preview. Softimage will apply an openGL realtime material to your lowpoly rock and display it on the viewport. In my case, as I didn't generated any diffuse map, there's the noicon image plugged on the ultimap_preview rendetree node. I changed it to a neutral grey image, applied to color/specular/ambient sampler. Now open the shader node and play with the bump factor. here's a comparision between the hi and 3 different low poly meshes:
You can note a slightly better high frequency detail on the surface or rock #2, that's because its normal map have higher resolution (1024px) whereas the others have 512px maps. On the other hand you can see that rock #3 has better silhouette and resemble more the original hi-res shape, because it has more polygons. So in the end its all about a nice balance between mesh density x map resolution x lighting conditions x distance from camera.
that's it. I'm totally not an expert in games/realtime assets but this should give you a good start.
Re: Rock Generator
nice!!
Will play with that one soon. With the other ICE tools, we're getting some nice terrain setups to fiddle with
thanks for sharing!!
Re: Rock Generator
Fabricio, you're on fire! Great stuff! That looks to be very handy.
