Wave-Curl Compound by Werner Ziemerink
Wave Curl
Version 2.0. This compound uses Nulls to control and create the wavy deforms. The nulls can be
scaled to stretch the wave out or bulge them into more toon-like waves. I put a scene
together, and left the compound open for people to explore. Take note that the ICE
tree should be under post-simulation. Works nicely in conjunction with Amaan Akram's
aaOcean Suite.
local backup: Wave_Curl_2.xsicompound
Here is a wave curl compound Werner Ziemerink created.
It uses Nuls to create the waves. The nulls can be scaled to stretch the wave out or bulge them into more toon-like waves. I put a scene together, and left the compound open for people to explore. Take not that the ICE tree should be under post-simulation. direct download can be found here:
http://www.si-community.com/download/co ... Werner.zip
EDIT Oktober 09:
an newer Version of the compound can be found here:
http://www.si-community.com/download/co ... e_Curl.zip
edit: february 2012:
a new update is presented in this post later in this thread.
EDIT Oktober 09:
http://www.pixelpanic.de
- farhaad_yousefi
Re: Wave-Curl Compound by Werner Ziemerink
super cooool.!!!!
Very Nice...
WAAAWWW!!!!!
Eu é que tou com cenas? Tu é que tás com cenas!
http://lickingtheice.tumblr.com
http://www.mariodomingos.com
If Werner's rig could be refined and controlled in the same way that Florian uses his rig in XSI which he combines with Tessendorf..
Florian's amazing waves rig in XSI here: http://www.florianwitzel.com/com/milk/
[the Rigging the Waves making of on the right]
then oceans would become a snap in Softimage...
is anyone up to the task??
A room with twenty trillion corners is a sphere.
There's a direct Vimeo link to the making of here:
http://vimeo.com/groups/1693/videos/4697942
I've tested my Wave Curl Compound together withAmaan Akram's Tessendorf wave generator, and it works as expected.
You are right Dof. It would be great if people could build on top of this and see if they can incorporate some of the cool features seen in the Milk videos. My ICE knowledge is very limited, so any help would be awesome.
If you ad anything, post the file up here so that other people can have fun with it as well.
Very Cool
Keep up the work.
Keep up the work.
- Sherif.Nagib
That is friggin awesome @ Thanks a tons !
Has anyone tried it with Amaan's Ocean Compound? I got some nice results...will try to post some screen caps soon.
Here is a quick test I did with Wave_Curl and aaOcean.
Werner, very interesting result!
Hi there..!
Werner sent me a new version of his compound. I´ve put into the dowload folder. Take a look at the first post, please ;)
Cheers,
oliver
Cheers,
oliver
really nice!, i was wondering if it would be possible to use a weightmap instead of the nulls? to drive the curliness?
greets,
ardworx
greets,
ardworx
There is an update to the Wave-Curl compound...
The following image explains the fix and the new compound
Download it from here
Users browsing this forum: Bing [Bot] and 50 guests
