Animation Clips
Animation Clips
Does anyone know of any good tutorials on making animation clips im stumbling through it... I saw the example one that softimage did with the mocapman and the help files but still is not enough info.
Re: Animation Clips
Ok i have been able to store my source animations and now im mixing away but i still need to learn how to make my 3 objects appear and disappear in my annimation sequences...any suggestions would help.
Re: Animation Clips
Hi..!
Would you please be a bit more precise, what exactly you problem is? Thanks..!
oliver
oliver
http://www.pixelpanic.de
Re: Animation Clips
Lets say i have 3 objects all in same position/location but all are shaped different. Now i do not want all the shapes to appear at once i want to make a animation clips and have them mix so the objects appear and dissappear. Ok so the first animation clip one of the objects appears the other two objects stay hidden the second animation clip the second object appears and the first and thrid are hidden the third animation clip the third object appears the first and second stays hidden...
Re: Animation Clips
Hi..!
Hope I´ve got you right..so, take a look into the added scene and let me know ;)
Just made a quick setup. I´ve just stored an action for one mesh and one frame each, visible and invisible. Then just copied the actions and replaced the item name in the clip-ppg (you can find in explorer under scene/mixer/source/animation/ ). Then dropped them into the mixer and arranged the anim...hope this helps..!
cheers
oliver
cheers
oliver
- Mixer_test.rar
- (65.63 KiB) Downloaded 106 times
Re: Animation Clips
Yeah nice sample thanks...
I understand everything you did the only part is how to make the objects visible and invisible while animating them.
Also i tested this script today GP_easy_hide_unhide which works but is not the best way.
Re: Animation Clips
Ok i got it now thanks to your example was able to fumble through it...the missing element was the object/visibility properties there is a key at top left corner to stamp the visibility options to the animation...
- SimpleVis.rar
- Simple Visability
- (61.54 KiB) Downloaded 107 times
