found it:
https://groups.google.com/forum/?#!topi ... smTLdLQKVA
Softimage Explosia FX released!
Explosia FX
Not to be confused with Oleg's Implosia FX, a mesh scattering simulator— A new gaseous fluids (fire and smoke) simulator from Ukraine based company Blackcore
tech. This product features dynamic voxel grids, a CPU accelerated raymarched preview,
OpenVDB export, the »render from camera« feature — (see videos)
— all build around an ICE node-based workflow.
From the product page: ExplosiaFX is a fluid dynamics simulation tool currently integrated in Autodesk Softimage. It is constructed based on a dynamically resizing voxel grid with a modern multigrid solver and thus provides high quality results in reasonable time. Intensive usage of AVX instructions when available makes it extremely fast without any compromises. By supporting the OpenVDB volumetric format, ExplosiaFX removes the need to render simulated data in Softimage, makes easy pipelining possible, as well as external cache processing on the Softimage side. [..] cont'd on the product page (link at bottom).
For demo videos, see Oleg's vimeo and the youtube channel. Also, the ExplosiaFX google group was set up.
Discontinued - the product is not available for purchase anymore but a fully functional noncommercial version is still available in the si-community thread (and in local backup)
local backup: XSI_EFX_Workgroup_1.007_win64.zip XSI_EFX_Workgroup_1.007_win64_AVX.zip (for CPUs supporting AVX) XSI_EFX_SampleScenes.zip Documentation.pdf Package overview slides.pdf
company page: www.blackcore.technology / product page: /softimage_efx / CGChannel article / si-community thread
Re: Softimage Explosia FX released!
Hi all,
I just tried installing Explosia FX but run into the SoftimageExplosiaFX.dll bing marked red so nothing is working.
I tried following Olegs advice here:
Oleg Bliznuk:
Could you please remove 2 dlls from XSI_EFX_Workgroup\Application\Plugins\bin\nt-x86-64\ :
msvcp120.dll
msvcr120.dll
Then, if the plugin manager will highlight EFX as red, try to install this:
https://www.microsoft.com/en-US/download/details.aspx?id=40784
thanks,
Oleg
But still no luck. I am on Win7 Softimage 2015 R2 Geforce GTX 970.
I see several of you have managed to get it running in SI 2015 R2, so does anyone have a suggestion regarding how to fix this one?
Morten
Oleg Bliznuk:
msvcp120.dll
msvcr120.dll
thanks,
Oleg
Morten
[edit: made a mistake, confusing EFX with Physx plugin from Oleg]
- Superpositivo
Excuse me guys.
Probably it's me. But can somebody explain me how to make Explosia work?
To me it doesn't render (Mental Ray).
I quite don't get it the whole Path thing to put in the shader.
Can anybody give me a precise step by step, please please please?....
Hi, I can't get at the computer with my licensed explosia atm, sorry. And, on top of that, I've only ever rendered Explosia with Redshift - see my earlier post about how to do that. If I can find some time though, I'll have a look and see how to render with MR. Did you follow the 'getting started' video on the Blackcore site?
- Superpositivo
Thanks a lot for your answer. I saw also your post about that.
Actually I have to say that some hours ago I figured out what to do and now it's rendering. Maybe I should edit this post as SOLVED.
Quite an awesome work by Oleg.
I watched already on Vimeo the "Getting started" video and I don't know I how missed some little points. Probably I was too much thinking on a certain way and blind about what Oleg was showing. But now it works.
Thanks a lot again!
Thanks a lot again!
No thanks, but yes, would be good to edit that other thread as 'closed'. Good to know you got it working
That video is sped up so fast, certainly easy to miss one or two points. But A LOT of information in there!
Users browsing this forum: No registered users and 46 guests
