ICE Topology and parametric equations
- Hirazi Blue
Re: ICE Topology and parametric equations (Warning math here!)
Let me say it one more time: Wow! ;)
It looks like you've got a lot of fun with parametric equations Daniel ! Nice compounds, well done !
The Create Topo node (the little guy responsible of converting arrays to a true polygon mesh) is one of the simplest topo nodes, but I was convinced that it would be one of the most useful. Nice to see good applications of it like in your tools or in Implosia FX too !
- Daniel Brassard
- Contact:
Thanks Guillaume,
I like the topology node, it is a very useful node. The most simpliest thing are often the most useful. Thanks to you and the other Dev behind Softimage, you rock!
- Daniel Brassard
- Contact:
The Sphere revisited (second mapping)
Due to the property of the sine and cosine, the sphere has two parametric version.
The Sine can be seen as a cosine phased out (moved) by 90 degrees (half-pi) as illustrated below.
The second version of the sphere is:
x = f(u,v) = r * Cos(u) * Cos (v)
y = g(u,v) = r * Sin(v)
z = h(u,v) = r * Sin(u) * Cos (v)
u_start = 0
u_end = Pi
v_start = 0
v_end = 2 * Pi
r = 1
This version will create a sphere by rotating a full circle 180 degrees.
Below is the ICE tree and the result. I did not do a full 180 degree to show how the sphere is created.
u_start = 0
u_end = Pi
v_start = 0
v_end = 2 * Pi
r = 1
- Attachments
- Sin_Cos.jpg (16.38 KiB) Viewed 9827 times
- Sphere3.jpg (70.25 KiB) Viewed 9827 times
- Sphere4.jpg (76.8 KiB) Viewed 9827 times
- Daniel Brassard
- Contact:
Experimentation with the sphere equations
If you remenber the original equation of the sphere, we have:
x = f(u,v) = r * Sin(u) * Cos (v)
y = g(u,v) = r * Cos (u)
z = h(u,v) = r * Sin(u) * Sin (v)
u_start = 0
u_end = PI
v_start = 0
v_end = 2*PI
r = 1
but what if r was different for x, y and z like so?
x = f(u,v) = rx * Sin(u) * Cos (v)
y = g(u,v) = ry * Cos (u)
z = h(u,v) = rz * Sin(u) * Sin (v)
u_start = 0
u_end = PI
v_start = 0
v_end = 2*PI
rx = 1
ry = .5
rz = .75
We Get the Ellipsoid (squashed sphere). Here is the ICE Tree and result.
u_start = 0
u_end = PI
v_start = 0
v_end = 2*PI
r = 1
u_start = 0
u_end = PI
v_start = 0
v_end = 2*PI
rx = 1
ry = .5
rz = .75
- Attachments
- Ellipsoid.jpg (72.84 KiB) Viewed 9824 times
- Ellipsoid2.jpg (60.84 KiB) Viewed 9824 times
- Daniel Brassard
- Contact:
Football
To create a Football shape, we need to modify our original sphere equations as follows:
y = g(u,v) = r * Cos (u) - b * u (note the small modification)
u_start = 0
u_end = PI
v_start = 0
v_end = 2*PI
r = 1
b = 1
The ICE tree and result is provided below.
u_start = 0
u_end = PI
v_start = 0
v_end = 2*PI
r = 1
b = 1
- Attachments
- Football.jpg (77.61 KiB) Viewed 9820 times
- Football2.jpg (62.51 KiB) Viewed 9820 times
- Daniel Brassard
- Contact:
The Twisted Sphere
The Twisted Sphere is a variation of the second mapping of the sphere. The equations are:
y = g(u,v) = r * Sin(v) + b * u (note the modification)
This is similar to the one we have seen before but on the second version of the sphere equations.
u_start = 0
u_end = Pi
v_start = 0
v_end = 2 * Pi
r = 1
b = 1
The ICE tree and result is as below.
u_start = 0
u_end = Pi
v_start = 0
v_end = 2 * Pi
r = 1
b = 1
- Attachments
- Sphere_Twisted.jpg (71.75 KiB) Viewed 9733 times
- Sphere_Twisted2.jpg (69.22 KiB) Viewed 9733 times
- Daniel Brassard
- Contact:
The Top
The Top surface is a variation of the shpere where the radius is fed by a cosine function. The equations are:
r = Cos(2*u) (this is the only modification to the sphere equations)
u_start = 0
u_end = PI
v_start = 0
v_end = 2*PI
The ICE tree and the result is illustrated below.
u_start = 0
u_end = PI
v_start = 0
v_end = 2*PI
- Attachments
- Top.jpg (73.54 KiB) Viewed 9731 times
- Top2.jpg (70.91 KiB) Viewed 9731 times
- Daniel Brassard
- Contact:
The Cone
The cone is a variation of the disk. We use v to modify the shape and scale the circles. The equations are:
x = f(u,v) = v * Sin (u)
y = g(u,v) = v
z = h(u,v) = v * Cos(u)
u_start = 0
u_end = 2*PI
v_start = 0 (to invert the cone, start at -1 and end at 0)
v_end = 1
y = g(u,v) = v
u_start = 0
u_end = 2*PI
v_end = 1
- Attachments
- Cone.jpg (59.21 KiB) Viewed 9729 times
- Cone2.jpg (78.27 KiB) Viewed 9729 times
- Daniel Brassard
- Contact:
Cone Variation
In this variation of the cone, i use a scalar to control the height and base width. You can also modify this to have both control in x and z independently if desire.
The equations are
x = f(u,v) = r * v * Sin (u)
y = g(u,v) = h * v
z = h(u,v) = r * v * Cos(u)
u_start = 0
u_end = 2*PI
v_start = -1 (show the cone inverted)
v_end = 0
r = .126
h = 1
The equations are
y = g(u,v) = h * v
u_start = 0
u_end = 2*PI
v_end = 0
r = .126
h = 1
- Attachments
- Cone3.jpg (56.44 KiB) Viewed 9728 times
- Cone4.jpg (68.97 KiB) Viewed 9728 times
- Daniel Brassard
- Contact:
That is it for tonight ... next time The Torus!
- Daniel Brassard
- Contact:
Re: ICE Topology and parametric equations (Warning math inside!)
The Torus (hum ... Donuts!)
The torus is formed by rotating a circle that is offset from the origin. The torus is controled by two radius: a large radius that control the size of the offset and a small radius that control the thickness of the ring.
The torus equations are:
x = f(u,v) = Cos(u) * ( R0 + (R1 * Cos(v)))
y = g(u,v) = R1 * Sin(v)
z = h(u,v) = Sin(u) * (R0 + ( R1 * Cos(v)))
where
R0 is the large radius = 1
R1 is the small radius = 0.25
U_start = 0
U_End = 2*PI
V_Start = 0
V_End - 2*PI
The ICE Tree and result is as below.
where
U_start = 0
U_End = 2*PI
V_Start = 0
V_End - 2*PI
- Attachments
- Torus.jpg (72.73 KiB) Viewed 3230 times
- Torus2.jpg (82.19 KiB) Viewed 3230 times
- Daniel Brassard
- Contact:
The Torus second mapping.
Like the sphere, the torus has a second mapping as follows:
x = f(u,v) = Cos(u) * ( R0 + (R1 * Sin(v)))
y = g(u,v) = R1 * Cos(v)
z = h(u,v) = Sin(u) * (R0 + ( R1 * Sin(v)))
where
U_start = 0
U_End = 2*PI
V_Start = 0
V_End - 2*PI
where
U_start = 0
U_End = 2*PI
V_Start = 0
V_End - 2*PI
- Attachments
- Torus3.jpg (71.08 KiB) Viewed 3644 times
- Torus4.jpg (86.42 KiB) Viewed 3644 times
- Daniel Brassard
- Contact:
Torus variations
Also like the sphere, we can modify the equations to control the height, width or depth by multiplying each equations with a scalar.
The torus equations are now:
x = f(u,v) = a * (Cos(u) * ( R0 + (R1 * Cos(v))))
y = g(u,v) = b * (R1 * Sin(v))
z = h(u,v) = c * (Sin(u) * (R0 + ( R1 * Cos(v))))
where
U_start = 0
U_End = 2*PI
V_Start = 0
V_End - 2*PI
a, b and c are scalars to control the width, height and depth of the torus.
Below is a modification of the ICE tree in x,y and z with a stretch in height of the torus as an example.
where
U_start = 0
U_End = 2*PI
V_Start = 0
V_End - 2*PI
- Attachments
- Torus5.jpg (77.33 KiB) Viewed 3643 times
- Torus6.jpg (84.49 KiB) Viewed 3643 times
- Daniel Brassard
- Contact:
The Helical Torus
By adding a component to the y axis equation, we can change the torus to a spring type surface.
The equations are:
y = g(u,v) = Stretch * u + (R1 * Sin(v)) (note the modification)
where
U_start = 0
U_End = 4*PI
V_Start = 0
V_End - 2*PI
Stretch = 1
The equations are:
where
U_start = 0
U_End = 4*PI
V_Start = 0
V_End - 2*PI
Stretch = 1
- Attachments
- Helical-Torus.jpg (72.62 KiB) Viewed 3642 times
- Helical-Torus2.jpg (79.66 KiB) Viewed 3642 times
- Daniel Brassard
- Contact:
The Spiral Helical Torus (Shell)
An other of the Torus variation, this time we also control the size of the ring as its spiral around the y axis creating a Shell type surface.
The equations are:
y = g(u,v) = u* (R1 * Sin(v)) - Stretch * u (note the modification)
where
U_start = 0
U_End = 4*PI
V_Start = 0
V_End - 2*PI
Stretch = 1.5
The equations are:
where
U_start = 0
U_End = 4*PI
V_Start = 0
V_End - 2*PI
Stretch = 1.5
- Attachments
- Torus_Shell.jpg (76.68 KiB) Viewed 3640 times
- Torus_Shell2.jpg (82.86 KiB) Viewed 3640 times
Users browsing this forum: No registered users and 28 guests
