VorleX Muscle System
VorleX Muscle System 2.01 PRO
VorleX is a toolset for setting up a full body muscle rig. With VorleX 3.0 still in
development, VorleX 2.01 has been made available for free. Have a look at the VorleX Muscle System Short Reel
for a preview of the upcoming version 3.0 — for videos demonstrating Version
2.01, see the VorleX group on vimeo.
From the si-community thread linked below: The system is far superior to other similar products. The features and functions: Simple construction Classic control by means of 3 nulls Easy setup Incredible performance Realistic optimized dynamics The ability of symmetric duplication Unique skinning algorithm Skin sliding effect
local backup: VorleXMuscleSystem2PRO.xsiaddon VorleXMuscleSystem2PRO.zip (supplementary files - docs and samples)
author link: http://vimeo.com/groups/vorlex / si-community thread
Re: VorleX Muscle System
wow... just wow
-Thucydides
-Thucydides
The above post deserves to live on its own as a stand-alone, testimony to the greatness of this plugin, so no edit from me.
So where is the home/buy page?
Also, buying a license will ensure how many updates (or bug fixes versions, as I'm sure they are there somewhere)?
-Thucydides
-Thucydides
Thanks!McNistor wrote:The above post deserves to live on its own as a stand-alone, testimony to the greatness of this plugin, so no edit from me.
For now you can purchase the Essentials version via email kosyyan@mail.ru.McNistor wrote: So where is the home/buy page?
Bug fixes will be for free, of course. Also you can freely update the plug-in with optional scripts and features if they appear.
Pro version will be available soon (at an additional cost).
I emailed you trying to price info, never heard back from you.
Phil Harbath
Jamination Productions
what happened to this?
I'd love to use it but it seems to have been discontinued
any news?
any news?
+1willp wrote:what happened to this?
any news?
Actually as far as i know those guys are at work on this super tool, theyre very patience as i am trying to use theyre systems with some "alternative" methode on face rigging for a short movie i am working on this will differentiates from anything actually avaiable on the market.
Salute!SamHowell wrote:+1willp wrote:what happened to this?
any news?
You should not have to worry. The work is going on. There are some difficulties, but they are surmountable. For now you can purchase VorleX Muscles Version 1.0 via email: kosyyan@mail.ru. The new version comes out soon.
Any questions you can ask here or in PM (or by email above).
Also interested to hear the status of this plugin..
Currently two key features of the new Pro version already implemented. These are the Mid Control Element and the Muscle/Obstacle Collision tool.PeterCGS wrote:Also interested to hear the status of this plugin..
The new features are implemented as additional options to maintain versions continuity. You can still use the muscle system in common manner, in Version 1.0 style.
Hello, guys.
An important update came out for VorleX Muscles. Download updated v1.0 VorleXMuscleSystemTrial.zip
The skinning process is now dramatically simplified. You no longer need to perform a lot of tedious routine operations manually to set up your skin.
Calling the VorleX Muscle Skin Setup command helps you automatically create the complete Vorlex skinning framework, including: intermediate muscle object, ICE Trees and compounds, special shape keys, weight maps, etc.
The VorleX Muscle Skin Setup command also creates a Custom Property that allows you to fast and easy reset your skin. Pressing one single button located on the Custom Property PPG will perform all the necessary operations.
A command's Help article you can find in the User's Guide.
1. Using Menu Command to Set Up Skin
To set up skin using menu command do the following:
· Make sure your Skin object has a standard envelope deformer in its operator stack.
· Place all your Muscle meshes in a Group (or combine them into the one single mesh using the Merge command).
· Choose Get > Property > VorleX Muscle Skin Setup… command from any toolbar (or Edit > VorleX Muscle Skin Setup… from right pane).
· Pick your Skin mesh first. Then pick the Muscle Group (or the combined Muscle mesh).
Finally paint the VorlexWeightMap to define the muscle influence area, and sculpt the StartRaycastShape shape key to achieve skin sliding (as described in Quick Start tutorial).
2. Using Custom Property Button to Reset Skin
To quickly reset your skin:
· Bring your character into a rest (neutral) pose.
· Locate the VorleXMuscleSkinSetup custom property under your Skin object in the explorer. Open its property editor. Press the "Set Skin" button.
This video illustrates certain new features of the VorleX Muscle System 2.0
- Mid Control usage
- Skin Setup menu command
- Smooth Skin function
- New Custom Falloff mode
See HD-version on Vimeo.com
- Mid Control usage
Very nice presentation of the features, although a full body (or at least upper or lower half) would be even nicer.
It seems to me that there's too much springiness, jiggling like an arrow when it hits the target and I don't any part of a human body (or animal alike) that behaves like that.
Is there a control for springiness?
-Thucydides
-Thucydides
McNistor sometime ago I've beta-tested the 2.0 version on the shoulder girdle muscles.
I think it works fine although usually there are a lot of problems with these muscles
It looks good, implementing it to a custom rig still looks daunting.Sherkon wrote:McNistor sometime ago I've beta-tested the 2.0 version on the shoulder girdle muscles.
I agree with McNistor, while the belly case is a extreme situation and it was nicely presented, real use cases are much better to evaluate the thing...
So those last two videos you posted are much better, IMHO, to see what this is all abot. Results look quite nice really!
Gustavo Eggert Boehs
Users browsing this forum: No registered users and 90 guests
