SiScatter
SiScatter 2.0
A scattering plugin from Julien Carmagnac, author of »Instance On Curve«.
SiScatter offers a high level of control over the scatter placement:
This scatter tool distributes particles based on the »emTool _ Equal Distribution on Surface« Compound from Eric Mootz (thank you Eric !). I tweak this compound to work together with »Delete Particles Near to Boundaries Edges«, »remove closest geometry« and »remove inside filter« compounds.
This tool build an ICE Tree and create a custom property under the point cloud object to tweak all ICE parameters. So you can edit entirely your scattering without open your ICE Tree. List of avalaible modifiers: color by gradient color by shape id color by texture map filter by boundary edge filter by closest geo filter by fractal filter by random [..]
Continue reading in the si-community thread. Video demo here.
local backup: siScatter.xsiaddon
Re: SiScatter
Can you enable all "Generic" check box ("shape" tab on properties) just to see if you have your big tree display in viewport ?
Re: SiScatter
if it enabled big tree is gone, and if it turn on big tree is back again(
Re: SiScatter
Thank for this plug in, is fantastic. I would like to know one thing please:
I tryed to use a texture like filter, but i'm not able in any way to write the "string" inside the TEXTURE name box.
So for example, i have in the scene a texture called ROCK.psd what i have to write in the texture box to point tothis texture?
I tryed all, but i never found the way to make it work .CAn some one help me please? Thank you!
Re: SiScatter
don't know really about this setting but this is likely to be an ICE TEXTURE MAP lookup.
So, there is a big chance you need to reference a softimage TEXTURE MAP (not a texture)
here an explanation http://softimage.wiki.softimage.com/xsi ... eColor.htm
Re: SiScatter
I'm sorry but there is no way. No one have be able to make it work? Thank you!!!!!
Re: SiScatter
You don't write the name of the image file. You just access the texture map that contains the image.
Re: SiScatter
Can you please do a example? I tryed this too, but i didn't workkk thank!
Re: SiScatter
Hello @yashugan !
Thank you for your comment !
About texture map, I notice that you just need to recreate the "Get Data" node inside the "siScatter _ Filter by Texture Map" compound : cf. screenshot
I don't understand why for now, I need to investigate more..
Re: SiScatter
A way more simple solution :
Just disconnect the "siScatter _ Emitter" node, and that will be ok (it may make a double reference that create a sort of path error).
Re: SiScatter
I'm sorry but i don't work:(
There are possibility to fix your interface with a more direct "texture " picker to filter the objects? Thank!
Re: SiScatter
Yes, I will update the addon, but in the meantime it may work !yashugan wrote:I'm sorry but i don't work:(
cf. gif animation for the full explanation step by step (sorry for the gif size/compression..)
Let me know if you still have problem.
Re: SiScatter
ho yeah!!!!!!!!!!!!!!!!!!!!!!!! thank you!!!!!!!!!!!!!!!
this will help my work 1000 times!!!!!!!!!!!
Fantastic! and thank again for the patience with me!!
Re: SiScatter
Hello !
I've just upload a new version of siScatter (1.6) with :
Gif Quick Demo A Gif Quick Demo B
- - New alignment options based on emitter's border edge :
- Cutoff distance
Orientation offset with variance
- an accurate Neighbors delete with distance option
- Cutoff distance
Re: SiScatter
Thanks Julca, this has been one of my favourite collections of nodes!
Re: SiScatter
Thanks Julca. Such a great scattering toolset.
Re: SiScatter
Fantastic! i'm really happy! i'm doing landscapes just in those days, and your scatter is simply awesome! thank!!!!!!!!!!
Users browsing this forum: No registered users and 45 guests
