Select Materials without Shader from Model
Falam
Post by Falam » 05 Jul 2013, 19:39
//JScript
//How do you search within the model for materials that don't have a specfic shader ?
// One thing I realize that X3DObject is strictly any [object] in the scene, similar to DOM.
oRoot =  ActiveProject.ActiveScene.Root
var sphere = Model.FindChildren("model", "#model",);
oRoot = MaterialCollection.find("Material")
I added the comments within the code snippet. The goal of the script is to search within a model, and select any materials that don't contain a specific shader node in the rendertree.
This code is completely separate, debugging test.
//JScript
var oNull = oRoot.addNull( "thenull" );
var oCamera = oNull.AddCamera('camera','mycamera');
var link = ParentObj ("oNull","oCamera");
Root.LogMessage = ("objects parented");
Wondering why the LogMessage isn't displaying the string. I replaced the string in LogMessage with a variable, no message is logged.
xsisupport
Re: Select Materials without Shader from Model
Post by xsisupport » 05 Jul 2013, 22:04
I already suggested how to figure out whether a material does or does not contain a certain shader: get all shaders under the material and then search that.
Did you run that debugging snippet? Surely you must have got an error for the ParentObj call???
And since it's Friday:
var LogMessage=new Object();
LogMessage.LogMessage="LogMessage"
Application.LogMessage( LogMessage.LogMessage )
// Steve Blair
luceric
Post by luceric » 05 Jul 2013, 23:09
Falam wrote:
what were you thinking when you wrote that?
Falam
Post by Falam » 06 Jul 2013, 04:27
oRoot = Application.ActiveSceneRoot
var oCamera = oRoot.AddCamera('camera','mycamera');
ParentObj ("thenull","mycamera");
Application.LogMessage(oRoot);
Next Select Materials Script.
myara
Post by myara » 30 Jul 2013, 12:49
Falam wrote:
Why do you want to log the Scene Root?
Just a tip, if you use a variable when you create "thenull", you'll have it as an object.
Then you can add a camera to this object and ParentObj won't be needed.
var r = ActiveSceneRoot
var n = r.addNull("theNull")
n.AddCamera("camera","mycamera")
And if you are writing in Jscript and you're not planing to translate it to python, then you don't need to write "Application" all the time. Even then, you could use a variable for that.
Falam
Post by Falam » 30 Jul 2013, 15:51
myara wrote:
Falam wrote:
Your making the Camera a child of the Null, correct ?
myara
Post by myara » 30 Jul 2013, 16:06
Oh, nevermind, I got it wrong.
