Hey guys, friend of mine sent me an animated procedural object with UV, format is Alembic.
Using SI2015 importing the animation does not seem to import the UV data. The animation is fine, but the UV simply are not there.
When i try to import the same alembic file into maya, it reads both the animation and the UV.
is there something to do on Softimage part to read the UV?
Houdini to Softimage, animation with UV Alembic
Re: Houdini to Softimage, animation with UV Alembic
Have you tried using crate to import the alembic?
crate was discontinued i dont have it also i think it was not updated so i dont think it will work, been years, i checked the website.mattmos wrote:Have you tried using crate to import the alembic?
I just thought SI 2015 had good alembic by default, but apparently not
It was released open source and there is a plugin for 2015, so it may work:
http://exocortex.com/blog/exocortex_cra ... pen_source
wow that comes as a great new to me, thanks i'll try
yeah it worked perfectly, thanks again, saved my life! and big thanks to Ben and Exocortex for making it available!
