Even UV Texture
Even UV Texture
is there a way other than manually, to evenly lay the UV texture on the mesh ?
I have a 180 degree cylinder wall (no top and bottom) and want to evenly cover the whole texture with the UVs, so each UV has the same width, and the whole texture is used.
What I have right now is this:
Pls share.
Regards,
Frank
Pls share.
Regards,
Frank
Re: Even UV Texture
Can you recreate the cylinder from scratch? that would be the easiest way, just create a default cylinder with default cylindrical projection and you're there
Re: Even UV Texture
thats one of the most annoying thing i've always come across. Curious how people approach this.
Re: Even UV Texture
ya, the cylinder projection is working fine now. Before I forgot how to update the adjusted UV info from the texture tool for maxwell render, that's why I was checking to do it manually. But now I found back that the Texture_Projection_Def just needs to be freezed before rendering.
Re: Even UV Texture
Still curious as to how people solve this problem in cases where recreating the UV is not an option (or not a simple cylinder type but a more complex one). 'Equidistant distribution' (of selection) would be a description to fit the bill. 'Relax' sounds like it could do it, but it doesn't. How do you guys tackle this?
Re: Even UV Texture
"Contour stretch" projection can do that, one of it's modes. But, it wants open stripe, in case of cylinder there's need to disconnect some edge and slightly move vertices on one end, in order to allow selection of vertices. It should be launched form TE. In most cases, two selected points ( on same side of stripe) should be enough.druitre wrote:Still curious as to how people solve this problem in cases where recreating the UV is not an option (or not a simple cylinder type but a more complex one). 'Equidistant distribution' (of selection) would be a description to fit the bill. 'Relax' sounds like it could do it, but it doesn't. How do you guys tackle this?
If not SI, Blender has nicely refined contour stretch thing, called "follow active quads". Firstly, quad like projection should exist on just one 4 point polygon ( or few), somewhere inside selection of polygons. This one is used as reference for entire selection. No need for disconnecting, it's not limited to stripes. With some basic skill, nothing hard to do nice UV on pipes, simple trees or like.
Re: Even UV Texture
It would be straightforward to do With ICE I think
EDIT.. it wasnt quite as straightforward as I hoped but I managed to get it to work. The second mesh is to do a minor adjustment to the UV.
https://dl.dropboxusercontent.com/u/8221942/evenUV.scn
Re: Even UV Texture
Mathaeus, thanks. I played around a bit with contour stretch and learned a few new things. Good to know!
As it happens I'm just in the process of modeling a (bit more complex) tree and maybe this is something to help get good UVs.
Paul: I'll have to study your tree to see what you're doing but it works, thanks. Is this specific to this object and set of UVs or is it a general principle that can be put into a compound and re-used across many situations?
-Jasper
-Jasper
Re: Even UV Texture
Hi Pooby,
I've downloaded your scene, in the Texture Editor the cylinder uses part of the whole texture yet. Is there something I need to run to make it fit ? Or what does the ICE tree do ?
http://files.2he.com/uploads2/2013_10_18_19_10_18.jpg
Pooby, can you help me with this other task too :O http://www.si-community.com/community/v ... =26&t=4452
Cheers,
Frank
Cheers,
Frank
Re: Even UV Texture
Hi Jasper, This compound will work for this type of object, but that's it.
It's not working in that JPg. Many of the nodes are red. I'm not sure why without looking at the scene.
As for the other task with the projections.,It sounds very difficult. I can't guarantee I could do it. Reverse engineering mirror shapes is not something I have an immediate idea about. But I don't mind taking a look.
Re: Even UV Texture
ok cool, can we do a google hangout by a next chance ? Today I'm fully occupied, tomorrow could work, I'm in Berlin (time).
Re: Even UV Texture
We could chat on Monday. I'm IPad only at the weekends.
Re: Even UV Texture
Frank1000: you need to connect the execute to the ICEtree, that's all.
Re: Even UV Texture
Hi Paul, tried to use the ICE on a half cylinder. I have made a compound from the ICE tree and created an own ICE tree for the half cylinder and copied and connected it and picked the half cylinder as object, but is not yet distributing the UVs evenly there. Is the same compound good for a half cylinder at all ?
Regards,
Frank
Working case
Not yet working case
Regards,
Frank
Working case
Re: Even UV Texture
Search for UV netalign in rray.
This tool works with "grid like" UVs. It doesn't work with complex UV shapes.
How to use it:
It is a simple script, not a plugin so create a button or run it from your Script Editor.
Select your UV grid samples ( you need to use Sync Method in Samples because the script relies in the viewer selection )
Run the script and your mouse cursor will becom a picker. Pick the first upper left sample in your UV mesh in the Texture Editor.
You'll have a few options, to align vertical and/or horizontal samples, or set a fixed distance to equidistantly rearrange your samples.
Now wait.
Done.
It doesn't work properly with unconnected samples, so you may need to heal your UVs before use it.
How to use it:
Now wait.
Done.
