Kristinka Hair Tests
Re: Kristinka Hair Tests
Sad news, friend. To be honest, as I mentioned earlier in a discussion, I'd like to use both, both has it's strength. At this moment I need to create hair, that can be baked onto a low poly surface. Or, if I could do a good geometry representation, that'd be the best. My ICE knowledge is far from the enough to resolve this.
First I wanted create MT_Extrusion. With strips, I was close enough, but I need a tapering effect but I couldn't reolve it.
I tried to to use the new ICE modeling feature, but for some reason the polygons created with the new extrusion along strands are placed in the origin, not taking the form of the guide strands...
Unfortunately the task is to make believable hair with Softimage, similar to the Samaritan video hair...Polycount (almost) doesn't matter
PS. By the way do not abandon MR support please, not everyone has access to 3delight, Arnold, and so on, please
First of all, 2 core version of 3delight For Softimage is free. How fast it is, when comes to hair rendering, you'll need to try.
Problem exactly begins from kH2 Emit Hair node, when it tries to create barycentric coordinates for guides/hair interpolation, performing a few simple math calculations on
very short distances, between hair/guides roots. In latest Kristinka Hair (now I *realy* hope you're using the latest one), there are a two simple methods to avoid this:
1: sampled root positions were slightly 'pushed' along emitter normal.
2: in case the hair root can't find all three guide roots, needed for 'even' interpolation, compound will switch to another interpolation type (just 'extrusion' along single guide). This can happen with a very low counts of guides, also some modifiers such as kH2 Follow Curve, are able to force that.
From my knowledge, these methods are usualy enough.
AFAIK, Melena doesn't use this way of hair filling. I think it's a random spread around guides, instead of searching the guides in another point cloud and creating the barycentric cords. So, temporal solution in Kristinka Hair would be to just avoid the second, filler point cloud. I think a lot of people are doing exactly that. Disadvantage is a much slower FPS, advantage is a much more predictable styling.
Now, a little surprise. In image bellow, I've intentionally disabled the first method (otherwise, everything is OK here, in Mental Ray too). As you can notice, 3delight still does the job as you expect ! You'll also notice both diffuse colors from hair shader - in Mental Ray image, that's only 'B' color.
AFAIK, it takes about few weeks for 3delight guys to make 'ground' for ICE strand rendering (counting from first announce on forum, and I'm pretty sure this wasn't their only job). Also, I've been able to finnaly figure out some very important facts about motion blur (for me, artist), just from a few short answers by their team lead.
Now, is it a Mental Ray issue or Softimage issue, I really don't know and I don't care of. However, as an artist, I'm 101% sure that the way of developing and distribution of Mental Ray, is not suitable for such complex product as modern renderer is. Probably a gamer graphic cards can go in this way of mass production - if some glow effect doesn't work in your game, you'll switch it off and you're OK. But the renderer simply needs more love, that only small, dedicated team can put into product. It's not only about 3delight. Max's users will know, if Normal Map shader in Max doesn't work well with Vray, they will not wait, they will write a special Normal Map shader for Vray.
It's not that I don't want to support this or that, I just have not a time for doing a nasty workarounds for each version of SI/MR.
btw, If you aren't absolutely sure about all mechanisms inside the ICE compounds, please do not mix Melena and Kristinka Hair.
Thanks Matheus,
I see your point, and agree with it.
I didn't intended to mix compounds of Kristinka and Melena, but use a mixture of Melena Hair and Krisitinka Hair...both has advantages. Unfortunately I couldn't bake hair in MR, so my project is stuck...
Anyhow, just aquestion, if you have access to SI 2012, do you know why the new extrusion along strands doesn't make the extrusion with Kristinka Guides?
Jester
PS. I'll check the 3delight, because I'm also frustrated by MR many times...That's why I gave up rendering a time ago...
Jester
as soon I'll have a time to play with trial, I'll checkout the extrusion stuff.
In the meantime, I think it may be one or both of two:
1:
some attributes are missing, as kH2 Emit Guides sets only necessary. You can take look into ICE tree that generates the extrusions correctly, then find in emitting node, and/or strand creation node, what attributes it sets. In 'emitting' node, that might be 'init particle data' node or something (copy this one and plug it after the kH2 Emit Guides). Then you can try to set another attributes from strand creation node (Self.StrandThis, Self.StrandThat...).
Two very important attributes for proper extrusion, strand up vector and strand tangent, are defined as custom in Kristinka Hair (ironically, in order to make the connection with old MT extrusion, to prevent the ICE to kill it's 'own' attributes).
So at the end of ICE tree (exactly, after the last 'deforming' node), you can set:
Get Data> Self.kH_UpVectorAlongStrand > Set Data> Self.StrandUpVector
Get Data> Self.kH_StrandTangent > Set Data> Self.StrandTangent
also...
Get Data> Self.StrandPosition > Set Data > Self.StrandCenter
.... or anything of factory stuff that sounds like this.
2: Point Cloud created in previous version of SI (I don't believe this may be a problem). Anyway, you can try to create a new point cloud, then just copy all the nodes form old one. Easy way for that: in 'old' point cloud, plug everything into execute node, instead directly into main ICE port. RMB on execute node, copy, paste into the new point cloud.
1:
also...
Matheus,
Do you have any idea if 3delight can bake hair to texture? In game developement it's very useful feature...
Jester
Jester
If you mean finding a farthest strand/hair segment, looking from surface of hair emitter (or something close to this shape), along surface normal - and storing the distance in bitmap...j3st3r wrote: Do you have any idea if 3delight can bake hair to texture? In game developement it's very useful feature...
Hardly I could imagine this in out-of-the-box 3delight for SI plugin.
Anyway, if default, Mental Ray render-mapping doesn't work correctly if you're using a long distance from surface (that is, tracing a ray 'back' to surface, along surface normal)... probably you can simplify process (to SI, not to user ), by just pushing the copy of mesh to cover the hair, inverting normal, then render-mapping with AO, using a very low angle (or zero) for spread. Then you'll need a color_math_basic node to subtract result from 'push distance', probably some change_range to fit all into 0-1 range, if it's needed.
Honestly I didn't tried all what I said, but I believe this should work.
Btw I could imagine an ICE way for this, but I believe the render-mapping (with MR) should be an easy way.
Regarding strand extrusions, I just sow the answer on SI mail list, from mr Laforge:
'If the extrusion is not generated it could be for two reasons.
"Create Extrusion Along Strands" doesn't need some orientation attributes on the point cloud. That's because it does its own calculation to find the good orientation. To do this, it is using the point position and the first strand position as a tangent basis. So maybe Melena system create the first strand position on the point position ? If so, the extrusion will not work. What you could try is doing a remove form array on strand position to remove the first element (as it is not needed in fact).
Also, if Melena create strands with some non constant number of positions (like 10 strand position on point 0 and 15 on point 1), it could give some trouble.'
So it might work with Kristinka Hair, theoretically. Mentioned 'first strand position on the point position' is not default option, even it's possible to enable it with 'Start From Root' in kH Emit Guides node. Also, strand positions are 'non-constant' only if you're using 'kH Optimize' node.
Anyway, mentioned method of calculating the rotations (I think it's similar to 'Deform by Curve'), IMHO, is not the best idea for any decent hair styling, as just the first tangent constantly changes. Probably this looks like good idea in first two days.
So, if there is compiled version of Melena, I would go with extrusion operator from Melena. Btw, Helge gently left the up vector as an open option, and adaptation of 'Prepare for extrusion' node that you'll find in KH pack, automatically takes already created up vectors.
Also, if you aren't ICE enthusiast or TD, and you can afford another 3d software, probably you can go with professional solution: Hair Farm plugin for 3d Studio Max. AFAIK, anyone with these two 'qualifications', already did that.
cheers
cheers
Hi all,
I'm currently looking at the "Create Extrusion Along Strands" problems.
It looks like it works correctly with Krinstinka hair system ...most of the time. I've got some artifact on the roots of the meshed strands sometime but I found the problem. I'm also looking at making it working correctly with Fabricio excellent Strand Tree compounds. Those problems should be fixed very soon, so I will send you a link to a new version ! I couldn't find time to test non-factory compounds before, but I just wanted to say that i will do my best to support compatibility with those public compounds !
Cheers,
Guillaume
Cheers,
Guillaume
Thank You kindly! Of course, I can adapt Kristinka Hair too. Unfortunately I still didn't had a chance to play with SI 2012, otherwise I would try to do something... Any info is helpful !
cheers
cheers
You are welcome Anto .
Here is "Create Extrusion Along Strands" V2 working with your hair system (and also Fabricio procedural Tree) : viewtopic.php?f=15&t=1456
Thank You, Master!guillaume wrote: Here is "Create Extrusion Along Strands" V2 working with your hair system (and also Fabricio procedural Tree) : viewtopic.php?f=15&t=1456
Well, now I need to stop with my 'happy negative' approach to forum life, probably forever
Back to Jester's question, particularly for Kristinka Hair nodes, 'custom array of up vectors' is defined by custom attribute called kH_UpVectorAlongStrand.
Generally, 'form' ('orange') nodes, always creates this attribute in some way, and it's often used by 'modifiers' (curls, bend, push...).
So, for getting the behavior of 'aligned' meshes, for example meshes aligned to NURBS surface used for kH Follow NURBS node, it's enough to type into Get Data node:
, plug this into the custom up vector input, enable 'vector mode' - that should be all. There is *no* need to activate 'Start From Root' option in kH Emit Guides.
Btw, maybe it's interesting maybe it's not, here is short overview of two variances of 'Fill Interpolated Array' (or 'Build Linearly Interpolated array') node.
Node is a 'working horse' for strand generation.
Second is a 'first strand position on top of point position', which is more elegant, there is no need to calculate the point position separately, you can just use 'Select in array' and fit the point position to first strand position - but in some cases this can cause problems, if something tries to create 3d vector (that is, tangent') in between. Let's say, in rendering, 'short hair' shading model uses just this, 'root normal' to simulate the normal of underlying surface ( at least that's how I understand this).
hi first thanks to Mathaeus for the wonderful k hair.
i'm really new to ICE so forgive me if my question sounds foolish XD
i've got this hair set up but some hair is going into the character mesh, i managed to detect hair whose emit location is inside the mesh and delete them, but i am not so sure how to style the hair so that they appear to collide with the mesh and curl away from the mesh. it would be great if someone can point me in the right direction, like which node to use etc. thanks in advance.
- Ding
- Ding
Hello,imding wrote: i've got this hair set up but some hair is going into the character mesh, i managed to detect hair whose emit location is inside the mesh and delete them, but i am not so sure how to style the hair so that they appear to collide with the mesh and curl away from the mesh. it would be great if someone can point me in the right direction, like which node to use etc. thanks in advance.
unfortunately there is no node in download, able to prevent any kind of interpenetration. Had some prototypes for particular cases, but never ever managed to have an enough global, robust and predictable solution for system, available for public.
hi thanks for the reply.
I'm not asking for a simulation function, all i want to know is which node in the current K Hair system is most suitable to style the hair to look like it collides with the mesh (maybe a few follow nurbs nodes perhaps), this is my 2nd time using k hair so some experienced suggestion would be greatly appreciated.
thanks again i really like these nodes
Can you perhaps have the frizz frequency start very small (small curls) near the scalp, and gradually go to current frequency at about an "inch" off the head?
I'm using the Syflex tutorial to make a Kristinka wig, and all has gone well -- but only when the character model is static.
In the top part of the pic, you'll see the roots are neat and aligned nicely. In the bottom part, I have the head rotated slightly and the roots start to twist and other parts of the hair become distorted. The further the rotation, the worse it gets.
In my setup, I have deformed emitter enveloped to the head bone. Is it better to make the wig at 0,0 and then move it up to the head?
Users browsing this forum: No registered users and 36 guests
