yet another GEAR problem
Hello
i wanna install gear on my laptop now
what i did was:
installed python 2.6
set PYTHONPATH to "modules" folder
dragged and dropped gear.xsiaddon to softimage
still dont get the GEAR menu
what i did was:
Re: yet another GEAR problem
First things first: does Python itself work on your laptop's Softimage?
Does it show up in the list of Scripting Languages?
Did you install Pywin32 & the 2005 and 2008 "Redistributables"?
Read this: INFO: Python on 64-bit Vista (should still apply)
actually python doesnt show up in softimage
where can i find the redist?
i triend to download these: http://www.microsoft.com/en-us/download/confirmation.aspx?id=5555 but they did not work
You are not perchance trying to install Python 3?
If you are "on 64", try using the archive mentioned at the above WIKI-page: PythonInstall64.rar.
Old, for sure, but the files should still work.
I installed everything in the link you sent me and even installed python 3 but im still not gettting the gear menu in softimage 2013 64-bit
Sorry, that's a misunderstanding: you should NOT install Python 3. But after installing those files, does Python already show up in Softimage?ibra wrote:I installed everything in the link you sent me and even installed python 3 but im still not gettting the gear menu in softimage 2013 64-bit
sorry im confused right now
all i see in softimage is Jscript and VB script
what should i install exactly
im on Win 7 64-bit running softimage 2013 64-bit
As you are on Softimage 2013 (sorry, missed that in your previous post),
shouldn't you just be able to simply go into the "Scripting Preferences"
and check the "Use Python Installed with Softimage (Windows Only)" checkbox?
I have that checked on
ok i uninstalled all pythons
what exactly do i need to install before dropping GEAR
I think you screwed up the python in softimage. re-register it with runone.bat
http://xsisupport.com/2010/06/28/python ... tall-2011/
i dont understand what happened, but that fixed everything!!!!!!!!!
thanks luceric!!!
thanks Hirazi Blue!!!
thanks luceric!!!
