ICE Kin - Constraint Pos
eternal art
What is the equivalent of Constraint compensation in regular Constraint when doing constrain pose via ICE Kinematics ?
grahamef
Re: ICE Kin - Constraint Pos
There isn't an equivalent. You could try to apply an offset by customizing the compound. However, it's probably easier to constrain the object's parent and then just move the object away from its parent interactively.
satyajit
- Skype: satyajit2000
There can be a workaround!
You can use static kinestates to compensate the constraints. Actually this method can be better in some places.
Take a look at the attached Position Constraint compound! Tell me what you think.
eternal art
thanks satyajit , i will take a look at it .
