Sycles 2.4.1 V 2.4.1 released August 2026 —
download page: https://ssoftadd.github.io/syclesSecondGenPage.html / wiki with tutorials / all of Shekn's plugins / author on vimeo / si-community thread
Nice updates =) These change range nodes are so intuitive to use, no need to use rule of 3..
Hm, I don't know what to say. May be this modification actually increase the render speed, but I didn't test it. Also I don't know what he change in official Cycles code.wireframex wrote: 19 Aug 2019, 17:36 Tell me what do you think about e-cycles https://evermotion.org/articles/show/11 ... in-blender ?
Small update 1.8.1. Download here: https://ssoftadd.github.io/download/Syc ... 1.xsiaddon
What's new:
1. Update OpenColorIO profiles to use the same files as in Blender 2.8.
2. Add new texture shader node WhiteNoise.
3. Add new mathematical operations for Math and VectorMath nodes.
4. Add Color output to the node ObjectInfo. For polygonmesh objects this color is taken from the wireframe color of the object (this color can be changed in Display property of any object). For pointcloud instances this color is taken from point color. This feature allows easilly vary colors of instances. Previously, if we generate instances by ICE and would like to use colors from ICE-particles, we need break instance connections and render it as independent objects. This technique described here (on Picture 2 example): viewtopic.php?p=61360#p61360
But now we can use the color of the point without breaking of the instance connections. Here is an example: All orange cubes in the picture have different colors, but all of them are rendered as instances of one master object.
What's new:
Thanks a lot to continue support SI
Boiler
Thanks man !! We (the last of SI warriors) Really appreciate this !
nuverian
MKXSI
Hi everyone,
I have different UVs in the same material for Color and normal but i dont see where can i choose from one or other UV when in the render tree, not in the cycTexture Coordinate node neither in the UVmap node. i could do it scaling texture with cycMapping but im sure there an easy way to do it.... any help?
Look at tutorial 24 on the manual (https://ssoftadd.github.io/manuals/sycl ... 19_eng.pdf). You should use the node cycUVMap and set the name of the map uv0 (for using the first coordinates) or uv1 (for using the second coordinates).
MKXSI
Just saw it a while after posting, thanks at all
MKXSI
Hi again, is it possible that rendering CPU+GPU goes slower than just rendering on CPU or GPU? Its happening to me
And also, is it possible that RTX 2080s renders faster than Threadripper 2990wx¿?
My build is:
Msi x399 Creator
Threadripper 2990wx
RTX 2080 Super
64Gb RAM
My build is:
Msi x399 Creator
Threadripper 2990wx
RTX 2080 Super
64Gb RAM
If it happens for you, then it is possible. May you find more information on the official forum for Cycles developers: https://devtalk.blender.org/c/cycles Also, if you think that something works strange, try to render the scene on the latest build of the Blender. May be the reason on the Cycles side, and may be Cycles developers know about it.
Hi MKXSI,MKXSI wrote: 17 Oct 2019, 07:29 Hi again, is it possible that rendering CPU+GPU goes slower than just rendering on CPU or GPU? Its happening to me
My build is:
Msi x399 Creator
Threadripper 2990wx
RTX 2080 Super
64Gb RAM
I own the same Threadripper 2990wx and 3 non RTX GFX-card (2x1080 + 1x1070) and I didn't notice CPU+GPU was slower than CPU or GPU because Cycles can work with multiple GFX Card
Nvidia drivers : 436.48
Windows 10 x64 / 64 Go RAM
Regards
Phil
jonmoore
For what it's worth V-Ray Next is faster when using GPU alone unless you have 20+ threads running at approx 3.5 Ghz plus. As it happens I have a dual Xeon with 40 threads @ 3.3 Ghz but still tend to render on GPU's alone (pair of 1080 Ti's) as I prefer getting on with other tasks whilst rendering animation sequences.wireframex wrote: 17 Oct 2019, 18:39Hi MKXSI,MKXSI wrote: 17 Oct 2019, 07:29 Hi again, is it possible that rendering CPU+GPU goes slower than just rendering on CPU or GPU? Its happening to me
My build is:
Msi x399 Creator
Threadripper 2990wx
RTX 2080 Super
64Gb RAM
I own the same Threadripper 2990wx and 3 non RTX GFX-card (2x1080 + 1x1070) and I didn't notice CPU+GPU was slower than CPU or GPU because Cycles can work with multiple GFX Card![]()
Regards
Phil
MKXSI
Hi all, it seems that depending on the bucket size CPU+GPU Render times and performance are affected.
Got another question, i cant get rid of fireflies or artifact in metalic material, using ;
AA 128
Dif 2
Glossy 8
transm 2
Ao 2
Clamp Dir 1
Clamp Ind 1
Denoise:
rad 2
feat strenght .5
strenght .5
any tips? i heard normal map strenght has effect on this, but i disconnected the normal map and its pretty much the same...
Thansk
AA 128
Dif 2
Glossy 8
transm 2
Ao 2
Clamp Dir 1
Clamp Ind 1
Denoise:
rad 2
feat strenght .5
strenght .5
Thansk
Post the screen with your problem. But any case, aa = 128 is to low. The render with this value will be very noisy. There is only one universals method to reduce noise and artefacts - increase samples count.
MKXSI
I guess that can be too of course, thanks for the tip, but is there any equivalence table to compare with arnold for example?
cause when i use arnlod, i use aa 8 and glossy 4 and there are no fireflies....
