Some help needed.
XSIconvert
Some help needed.
Post by XSIconvert » 10 Oct 2010, 16:28
Hello softimage community members,
Im new here on the forum, im also starting to learn Softimage. I normal use 3ds Max, been working with Max about 3 years now.
But when i saw some Ice videos and Lagoa and realised that its quite powerfull and very interactive compared to Pflow, Box,etc so i decided to learn this software.
Ive been using it for about a month now and i must say its awesome. Been playing mainly with Ice, some basic modeling,etc.
I have a basic question but i cant figure it out, ive made some cloth using a simple grid, applied a texture map (UVW map) to the grid assigned a material.
Looks as should, but when i simulate the material stays in place like its only projected to the grid, doesnt follow the movement of the grid. What im i doing wrong?
Thanks;
(Excuse my English)
XSIconvert
Re: Some help needed.
Post by XSIconvert » 10 Oct 2010, 17:41
Ok i figured it out, i had to 'freeze the texture projection transformations' in the texture editor.
Post by rray » 10 Oct 2010, 19:08
Hello XSIConvert
welcome to our little forum!
Another way to do it would be to use the explorer to locate the sample* cluster* under the object, and freeze the "Texture Projection" property directly below.
some softi lingo :-@ ....
sample = polygon corner, those items which can be assigned UVs
cluster = set of polygons, samples, edges or points (aka components)
the sample cluster is usually named sth like "Texture_Coords_AUTO"
-ray
XSIconvert
Post by XSIconvert » 11 Oct 2010, 17:15
Thanks for the info Ray,
