farhaad_yousefi
- Yahoo Messenger: farhaad_yousefi@yahoo.com
Post
by farhaad_yousefi » 18 Sep 2010, 11:42
hi
i have a still scene and i want to bring it to softimage ,bu i can not bring the textures.
even in exporting process i get the warning messege of images not found although i have them all in view and render in max,
izze
Post
by izze » 26 Sep 2010, 01:30
We use FBX from Max to XSI. Be sure to select FBX version 2006 in the export options from Max. Otherwise we get problems. Sometimes the materials come over 100% transparent, and the specular is really high. But, that is easily fixed.
farhaad_yousefi
Post
by farhaad_yousefi » 26 Sep 2010, 04:33
izze wrote:We use FBX from Max to XSI. Be sure to select FBX version 2006 in the export options from Max. Otherwise we get problems. Sometimes the materials come over 100% transparent, and the specular is really high. But, that is easily fixed.
yesss i get this transparency problem all the time.! why 2006.?!?!!? doesn't it suppose to get better by the time.!?
Post
by Hirazi Blue » 26 Sep 2010, 08:55
I don't know if this helps (or is even relevant), but there seems to have been a major change in FBX 2011:
Previously, FBX 2006, 2009 and 2010 releases have been based on FBX File Format version 6.1. FBX 2011 is the first release since 2006 to completely change the format of the technology.
Source
And according to the Softimage User's Guide: "Crosswalk for FBX now uses FBX SDK 2011",
so that is probably why they even introduced an article in the Knowledge Base called
Rolling back to an older version of Crosswalk
