Hello everyone. I am trying to create a synoptic button that when pressed once,
will enable the current weight influence of a constraint to 1 and when I press it again
it will roll it back to zero.
I checked the toggle value command on the script editor, but I think I´m not approaching
the problem and the syntax correctly (im using VB):
ToggleValue ("Rig.Ctrl2_Hand_LFT_IK1.kine.posecns.blendweight, 1");
Could anyone please help me to code that button, please?
Thanks.
David.
Toggle value between 0 and 1 to blend constraint´s weight
sirdavid32
sirdavid32
Re: Toggle value between 0 and 1 to blend constraint´s weight
Im switching to JS now, I got this:
if ("Rig.Ctrl2_IK1.kine.posecns.blendweight = 0") then
SetValue ("Rig.Ctrl2_IK1.kine.posecns.blendweight", 1);
But I get an error on the first line.
Any ideas?
Any ideas?
Web: http://www.3dcinetv.com
In your IF statement, all you have is a string.
You need something like this (in Jscript)
if ( GetValue("Rig.Ctrl2_IK1.kine.posecns.blendweight") = 0 )
SetValue ("Rig.Ctrl2_IK1.kine.posecns.blendweight", 1);-
sirdavid32
Thank you my coded now it´s working after adding the second =
Great! now I´ll go experiment with the boolean value.
agedito
A classic mathematic trick:
1 - 0 = 1
1 - 1 = 0
1 - 0 = 1
1 - 1 = 0
oldValue = GetValue("Rig.Ctrl2_IK1.kine.posecns.blendweight")
SetValue ("Rig.Ctrl2_IK1.kine.posecns.blendweight", 1 - oldValue );
