kine.local.rotz
xowgax
kine.local.rotz
Post by xowgax » 03 Aug 2010, 18:44
all this talk about ICE Kinematics, & I still can't figure out how to set data for "this.kine.local.rotz" while using 2011..
I think I'm missing something very basic..
I've seen the "Automatically Rotate Wheels With ICE" compound, but that changes point positions, is that still the only way to do it?
Re: kine.local.rotz
Post by Hirazi Blue » 03 Aug 2010, 18:52
There are two things wrong with the ICE Tree you show:
- You cannot set data on kine.local, only on kine.global
- you can write only to the whole kine.global matrix, not to components like rot or rotz.
xowgax
Re: kine.local.rotz
Post by xowgax » 10 Aug 2010, 18:06
Thanks for the reply, could you please explain (or link to) how the kine.global matrix works? ><
Re: kine.local.rotz
Post by Hirazi Blue » 10 Aug 2010, 18:33
This image from the manual shows a bit of what's going on. As you can set the data only on the full matrix of the kine.global there is an "SRT to Matrix" plugged into the "Set Data", exposing ports for "Scaling", "Rotation" and "Translation".
In this example the "Scaling" and "Rotation" are taken from the original matrix (via "Matrix to SRT")
and the "Translation" is taken from a different source.
"Scaling", "Rotation" and "Translation" can obviously be broken up further to expose the XYZ parameters.
I hope this makes sense, but I seriously doubt it! :ymblushing:
milesc
Re: kine.local.rotz
Post by milesc » 10 Aug 2010, 19:35
Here is my little compound "GhostChild" that may help.
It output the child matrix from a parent matrix and the SRT you want for the child.
It is use to replace the buffer objects need for rigging, which is the beauty of ICE kinematic.
