2011 to 7.5.!!
farhaad_yousefi
- Yahoo Messenger: farhaad_yousefi@yahoo.com
2011 to 7.5.!!
hi i have a simple animation by path..that i want my scene inside 7.5 but nothing no crosswalk to fbx nor exporting .xsi wouldn't do the job. is there any special thing .?! should i install crosswalk 4 and install ,?will it work by having the 5th version on 2011.?! what would be the best solution.!? much appreciated
g.m.
Re: 2011 to 7.5.!!
You could try to export with point oven, and then import it back to 7.5. I'm almost sure there are no backward compatibility issues with that, but probably there are other solutions as well.
g.m.
g.m.
farhaad_yousefi
Re: 2011 to 7.5.!!
problem solved i downloaded crosswalk 5.1 and exported an fbx..still got some problems but they're minor.!g.m. wrote:You could try to export with point oven, and then import it back to 7.5. I'm almost sure there are no backward compatibility issues with that, but probably there are other solutions as well.
g.m.
i actually wanted to work with vue 8.5 but it seems the synchronization plug in only works on 7.5 not even 2010.!!
if there's any solution.!?
