polygon uv sample to location?
jerry7
Post by jerry7 » 16 Jul 2010, 03:40
hi,
is there some nodes to get point position at every uv sample?
owei
Re: polygon uv sample to location?
Post by owei » 16 Jul 2010, 11:24
hi!
Do you mean texture UV coordinates..?
If YES, try this:
- get data node
- open ppg of get data node
- explore the object you like, dig down into CLUSTERS/Texture_coordinates../Texture_Projection
- here you´ll find several UVs (if they exist...)
- you will get a 2d or 3d point/vector on your get data node..
hope this helps!
cheers,
oliver
jerry7
Post by jerry7 » 19 Jul 2010, 01:26
yeah, I want to set texture UV coordinates with the different condition of vertex position. But the context is not match. How to solve it?
CiaranM
Post by CiaranM » 19 Jul 2010, 05:58
If you want the 3D space position of each UV sample (i.e. pointposition), you need to use nodeposition instead. This should be the same context as the UV coordinates.
jerry7
Post by jerry7 » 19 Jul 2010, 08:11
Thank you very much! it's just what i'm searching for.
