How to create a ramp like this?
jerry7
How to create a ramp like this in render tree? i can't make it with the gradient shader .
g.m.
Re: How to create a ramp like this?
You could set the gradient type to horizontal, add a cylindrical texture projection, then set uv generation to implicit on the texture_projection_def ppg. Maybe you need to change the projection plane of the texture support. Probably there's another way of doing this. Hope this helps.
Not sure if I understand you correctly, but couldn't you achieve this by setting the "Gradient Type" to "Radial Rainbow" and then editing the color markers accordingly?
g.m.
The radial rainbow didn't work for me, but maybe this screenshot explains my method better.
jerry7
it maybe can't apply to a sphere with many tiles.
g.m.
You could use the picture from your first post to create a texture in photoshop or is it necessary to do it in xsi?
jerry7
I want make a spin animation. Thank you anyway!
