How'bout Blender?
How'bout Blender?
Post by FXDude » 22 Nov 2026, 23:56
Hi ,
long trime no post!
Just to ask, what are your impressions of Blender?
for me, although I can recall mentionning how I wasn't "feeling it" in terms of proceduralism .... I SHOULD've added "YET".
Because in my impression, "linked duplicates" were basically instances, also based on all descriptions and tutorials etc.. and indeed does moving points around in edit mode, also does so on the original, while typically in various apps can instances only have transforms be varied.
Otherwise geonode outputs would not always be considered by subsequent modifiers.
BUT ... "linked copies" CAN have their own unique modifiers, and since I dont know when, it's possible to "make real" outputs to be picked-up by later modifiers and references from/to other meshes etc..
I'm so late doing stuff in geo nodes, ... also because whenever in Blender I'm still tinkering with the UI lol
But you can have a procedural mirror, or pushed-in-or-out version of a mesh, merged back with itself, and essentally do like "mesh compositing"
( didn't try any of that yet)
To a large degree can you select stuff based on all kinds of things, such as by angle, by distance or whatever you can define like subcomponents inside other meshes, before getting extruded, beveled, removed, or whatever you would want to do with selections.
(still wishing for an "edit mode-ifier", or an "edit mode node" but it seems to be getting there)
Geonodes can also handle particle simulations, armatures(very new)grease pencil elements, "grids" (VDB volume advection /processing), SDF's (signed distance fields),strings, curves, also allowing to convert to and from all of those things, can do UV manipulation/generation ... and physics are making their way, already having a hair and cloth solver,
In general, think geonodes is more approchable than Fabric Engine was, and to be fair, Bifrost doesnt seem so bad in that regard, but IO has to interface with the old (and probably forever messy/fiinnicky) node editor(also in regards to rigging complexity management with lots of ins and outs)
COMP
Otherwise ... Blender's compositor is faster than it was, and despite things that might be lacking relative to dedicated comp apps,
it's mostly it's connection / integration with "the rest of it" .. that can make it unique or interesting, also getting features from geonodes and or the shader editor (and vice versa) ... often not found in comp apps,
Can also do live post processing of 3D viewports (awesome!) as well as the fact that it has a shadertree type of nodetree (like in general with blender nodes),
with parameters shown in context on the nodes themselfves , which is also unique (in comp or otherwise) and GREAT for birds eye view of settings, and very EZ encapsulaing of node setups into nodegroups before exposing important parameters for tweaking or getting driven by something else ... also possible elsewhere, but the node editor is very natively "made for that".
Same goes with the video editor, it now has most of the basics or essentials for video editing, some things might be more streamlined in other video editors but it works with the compositor to add comp effects on top of strips, or to strips themselves, (like originally in FlintFlame, later DS, and perhaps later NkStudio, and i think After effects there was an addon for node trees on clips?) ... and it otherwise can literally edit un-rendered shots or 3d scenes lol
which makes it probably the most complete or advanced "camera sequencer" already being a now very complete video editor.
It otherwise became probably one of the best choices for NPR stuff... while being able to handle PR (photo realism) just fine.
2.8 was perhaps a milestone and Geonodes was perhaps another,
and perhaps like other apps such as Houdini and Unreal and dare i say it Maya made good strides in different ways,
also did Blender which never stopped just getting better than itself, we could say that Blender has been "on fire" lol
You can pipe any arbitrary custom things into custom "Arbitrary Output Values" (AOV) channels (also definable in geo nodes) ... you can have instances of the same scene each with scene wide or specific material overrides .......
one comp tree can reference multiple (unrendered) scenes, so rendering the comp, also renders the scenes, doing each frame of each scene one after the other, so everything is fresh in the cache, before moving-on to the next frame of each scene (or scene instance)
all pipe-able to a single (or multiple) exr sequence(s).
There were some requests about a "Takes" system in blender, but this even surpasses XSI passes or Maya render setups in my impression.
Nevertheless, it has been becoming, is becoming, and/or became ... actually quite good in alot of ways, or although it was always possible to do alot of things in Blender, it's is no longer at-all like "a compromise" relative to other things out there, and some things or aspects can even arguably be "better" or it can also definitely have it's own advantages, I would say, including relative to XSI (with perhaps some drawback or some remaining gaps ..which have only been closing)
It probably won't displace Houdini or Maya in bigger shops, maybe for similar reasons Houdini isn't quite displacing Maya (or vice-versa) despite each increasingly becoming more "general purpose", even game engines now have full modeling, rigging and animation toolsets today, all of which I guess is fine.
Also because probably nothing can be "better" than Houdini, and big shop have no problem soaking it all up, but the "barrier of entry" to Houdini, isn't that it's pricey, can be fine once or as you get use to it, but's like .. from very technical engineers, for very technical artists, while making Houdini more user-friendly, might also "dumb down" Houdini to some extents.
Bigger shops might also have issues with lack of C++ extensibility in Blender, but I've seen some plugins interface with external compiled libraries, but don't know how hard that might be,
In regards to becoming more "all encompassing", in Blender perhaps even more so became like an entire production suite in a box, although it's not common or suggested to do everything in one app, it's kinda already technically possible to basically do everything there, other than perhaps music authoring lol
What do you think?
Anyhoo, cheers, and nice to see this place still exists! :ymcowboy: ~o)
