VitLoss
Post
by VitLoss » 16 Mar 2025, 23:24
Hey, everybody!
I'm trying to write a script for softimage using (JScript or VBScript) very little experience in writing scripts, sorry if anything
The question is
How can I activate the Tweak Component Tool (key “M”) using JScript or VBScript?
Can I know if this Tool is active now or not?
Kolya
Post
by Kolya » 17 Mar 2025, 08:51
Hello! to activate Tweak Component Tool use TweakTool() command,
to know if it is currently active check if ActiveToolName property equals to "TweakTool", if(ActiveToolName == "TweakTool")
myara
Post
by myara » 17 Mar 2025, 08:58
I find it strange that you would want to learning scripting for Softimage now. But if you are starting with scripting, I'd recommend start with Python, at least that knowledge would translate to other DCC software like Maya.
But to answer your question, in JScript (similar but not the same as JavaScript).
To activate :
//JScript
Commands("Move Component Tool").Execute()
or
To query:
if (ActiveToolName=='TweakTool'){
M.Yara
myara
Post
by myara » 17 Mar 2025, 09:01
Kolya wrote: 17 Mar 2025, 08:51
That would be simpler
M.Yara
VitLoss
Post
by VitLoss » 17 Mar 2025, 20:50
"I find it strange that you would want to learning scripting for Softimage now."
yeah...
but I still can't break up with Softimage. )))
Thank you All! I'll try it.
VitLoss
Post
by VitLoss » 17 Mar 2025, 21:59
This is exactly what I needed
Thank you All again! =)
VitLoss
Post
by VitLoss » 12 Apr 2025, 14:52
Hey, everybody!
help please.
How can I get a list (array) of all texture clusters of a selected object? using JScript
myara
Post
by myara » 12 Apr 2025, 15:36
This would give you collections, not arrays.
// Get All Clusters
var oSampleCls = oObj.ActivePrimitive.Geometry.Clusters.Filter("sample");
var oPointCls = oObj.ActivePrimitive.Geometry.Clusters.Filter("pnt");
var oPolyCls = oObj.ActivePrimitive.Geometry.Clusters.Filter("poly");
var oEdgeCls = oObj.ActivePrimitive.Geometry.Clusters.Filter("edge");
M.Yara
VitLoss
Post
by VitLoss » 12 Apr 2025, 16:17
Thank You!
