SItoA-7.1.4
New plugins, tools etc.
Jenus
SItoA-7.1.4
Post by Jenus » 25 Apr 2023, 00:09
Long over due, I finally present to you a new SItoA version.
I was planning on releasing this a lot sooner but I suffered a total harddrive failure a while back and lost a bunch of uncommitted code. So I had to rewrite all of it.
Anyway... here it is.
SItoA 7.1.4 using Arnold 7.1.4.4
Release notes and xsiaddon for Windows is at the Github link below.
https://github.com/JenusL/sitoa/releases/tag/v7.1.4
I3D
Skype: ironic3d
Re: SItoA-7.1.4
Post by I3D » 25 Apr 2023, 07:48
Thank you Jenus, this is awesome. Thanks for keeping this alive. I always like to work in XSI as apposed to Maya.
I3D
Skype: ironic3d
Re: SItoA-7.1.4
Post by I3D » 25 Apr 2023, 09:08
Hey Jenus
I think I botched the install and now SitoA doesn't work anymore, even previous version, can you tell me what is wrong with this?
# ERROR : 2229 - Traceback (most recent call last):
#   File "<Script Block 2>", line 41, in XSILoadPlugin
#     Application.LoadPlugin(XSIUtils.BuildPath(in_reg.OriginPath, 'ArnoldTools.js'))
#   File "<COMObject Application>", line 2, in LoadPlugin
# COM Error: Invalid argument.  UI Items should be specified as a 1D array of String/Value pairs. - [line 40 in C:\Users\ironi\Autodesk\Softimage_2015_R2-SP2\Addons\SItoA\Application\Plugins\ArnoldDenoiser.py]
#   File "<Script Block 2>", line 19, in XSILoadPlugin
#     dllPath_release = Application.Plugins("Arnold Shaders").OriginPath + "bin\\nt-x86-64\\tbb42.dll";
# AttributeError: 'NoneType' object has no attribute 'OriginPath'
#  - [line 18 in C:\Tools\Softimage\VDB2SI_WG\Application\Plugins\bin\nt-x86-64\VDB_shaderDefs_ai.pys]
Application.InstallAddon("C:\\Users\\ironi\\Downloads\\SItoA-7.1.4-windows-2015.xsiaddon", 5)
This is now showing up even when I try to install 7.0 release.
Jenus
Re: SItoA-7.1.4
Post by Jenus » 25 Apr 2023, 11:52
I3D wrote: 25 Apr 2023, 09:08 Hey Jenus
Hi!
Looks like some error with another plugin there, VDB2SI_WG. Maybe the load order has changed. Go into plugin manager and make it so that SItoA workgroup loads before the other plugins by moving them up/down.
I3D
Skype: ironic3d
Re: SItoA-7.1.4
Post by I3D » 25 Apr 2023, 13:17
Thanks Jenus
I've removed the OpenVDB plugin and that removed the previous error. Still getting another error now, so removed all loaded plugins but not shaking this away, even with v7.0
# INFO : [sitoa] SItoA 7.1.4 win loaded.
# INFO : [sitoa] Arnold 7.1.4.4 detected.
trying to attach any material creates this error as well
# ERROR : 2011 - Member not found - [line 117 in C:\Users\ironi\Autodesk\Softimage_2015_R2-SP2\Addons\SItoA\Application\Plugins\ArnoldMenu.js]
# ERROR : 2011-CUST-SITOA_AddShader - Member not found
Application.SITOA_AddShader("Arnold.standard_surface.1.0", "surface", "", "")
# ERROR : Object doesn't support this property or method - [line 478 in C:\Users\ironi\Autodesk\Softimage_2015_R2-SP2\Addons\SItoA\Application\Plugins\ArnoldMenu.js]
Thanks for your help.
I3D
Skype: ironic3d
Re: SItoA-7.1.4
Post by I3D » 25 Apr 2023, 13:21
The only thing that doesn't seem to be loaded is the denoiser
I can see all the shaders, but trying to apply them to an object produces that error form the previous post.
I3D
Skype: ironic3d
Re: SItoA-7.1.4
Post by I3D » 25 Apr 2023, 13:39
Hi Jenus
I've wiped the preference folder and created from scratch. The install error is gone and no more errors are reported when install the plugins. But :) when applying any material I keep getting this error and there is no interface.
' ERROR : 2011 - Member not found - [line 117 in C:\Users\ironi\Autodesk\Softimage_2015_R2-SP2\Addons\SItoA\Application\Plugins\ArnoldMenu.js]
' ERROR : 2011-CUST-SITOA_AddShader - Member not found
SITOA_AddShader "Arnold.standard_surface.1.0", "surface"
' ERROR : Object doesn't support this property or method - [line 473 in C:\Users\ironi\Autodesk\Softimage_2015_R2-SP2\Addons\SItoA\Application\Plugins\ArnoldMenu.js]
Any ideas?
I3D
Skype: ironic3d
Re: SItoA-7.1.4
Post by I3D » 25 Apr 2023, 13:48
Issue is resolved. All that was needed was a restart for XSI and the shaders were loaded. Thanks Jenus :)
Jenus
Re: SItoA-7.1.4
Post by Jenus » 25 Apr 2023, 14:18
Haha yeah always restart after messing around with plugins :)
I3D
Skype: ironic3d
Re: SItoA-7.1.4
Post by I3D » 25 Apr 2023, 15:33
yeah I know, I forgot it's XSI. in Maya and blender it's rock and roll so I forgot for a minute that's not XSI 😂
X-said
Re: SItoA-7.1.4
Post by X-said » 26 Apr 2023, 10:07
Jenus, thank you for supporting this plugin for this render.
Pooby
Re: SItoA-7.1.4
Post by Pooby » 16 Dec 2023, 22:39
Just a question about licensing.. It appeared on github that sitoa was made free. Is that correct? I'm a bit confused as it doesnt appear to check for a license, but it still renders with a watermark. I wonder if anyone could tell me what the deal is?
I3D
Skype: ironic3d
Re: SItoA-7.1.4
Post by I3D » 16 Dec 2023, 22:48
You still need a standalone licensee to run sitoa. It was made free meaning open sourced, and prior to this the plug-in was always behind a gate to subscribers only.
Pooby
Re: SItoA-7.1.4
Post by Pooby » 16 Dec 2023, 22:57
Oh I see.. that's a shame
kilin_studio
Re: SItoA-7.1.4
Post by kilin_studio » 08 Apr 2024, 06:09
Thx my bro,I love xsi !
