aaocean ice foam
aaocean ice foam
Post by Maximus » 07 Feb 2023, 09:54
hey guys, im tryin to use aaocean ice setup and it works fine, im just trying to figure out how to use foam and how it should be set up and connected.
here is a screenshot, you can enable foam from the main aaocean compound and the node has a scalar output but i have no clue what to connect there and how to make it works.
anyone have used it and can help?
thank you!
Surface_VR
Re: aaocean ice foam
Post by Surface_VR » 11 Feb 2023, 05:52
Check the Foam checkbox and insert a Foam scalar into a weight map, for example, and use it as a filter for particle generation.
And if I use egnVector as velocity, I can create simple bubbles.
I'm thinking something like that, but if anyone has a better way to use it, I'd like to know too!
Post by Maximus » 11 Feb 2023, 16:32
i tried to replicate your setup but nothing works, my particles dont move and im a bit confused...
can i have your whole ice tree screenshotted?
Surface_VR
Post by Surface_VR » 17 Feb 2023, 14:42
I also took a video.
Post by Maximus » 17 Feb 2023, 16:51
thanks a lot, i really appreciate it, it works :)
Post by FXDude » 24 May 2023, 00:07
I used the "XOcean" deformer also for it's scalar output for weightmaps.
Did you try both ?
Didn't try AAocean (yet)
But they seem very similar, also for the available outputs !
