Center Selection Filter
gaboraa
Post by gaboraa » 28 May 2022, 17:02
Is there any way to get the CenterSelectionFilter command on Python? It is not reported in the output log when executed. Also, is there any place where I can look for all the commands that are not reported in the output log?
Kolya
Re: Center Selection Filter
Post by Kolya » 30 May 2022, 07:06
to check if center mode is enabled: Application.GetUserPref("SI3D_SRT_CENTER")
to toggle between: Application.SetUserPref("SI3D_SRT_CENTER", not Application.GetUserPref("SI3D_SRT_CENTER"))
myara
Post by myara » 30 May 2022, 07:59
As Kolya mentioned, selection filters are preferences, not commands. The command is SelectAllUsingFilter from which you have a log.
As for a way to list all commands, you just need to iterate Application.Commands.
Ex:
for x in Application.Commands:
	LogMessage ( '%s | %s | %s' % ( x.Name, x.Category, x.ScriptingName ) )
If it helps, this is a code I was writing to find some commands a long time ago. I never quite finished but it works:
# Find Commands
# 2016
# myara
xsi = Application
log = xsi.Logmessage
from win32com.client import constants as c
oPSet = XSIFactory.CreateObject("CustomProperty")
oPSet.Name = 'Search Command'
oPSet.AddParameter2( 'keyword', c.siString )
oPSet.AddParameter2( 'allkeys', c.siBool )
oGridParam = oPSet.AddGridParameter( 'resultsGrid' )
oLay = oPSet.PPGLayout
oLay.AddRow()
oLay.AddGroup("",0,90)
oLay.AddItem('keyword', 'Search' )
oLay.EndGroup()
oLay.AddGroup("",0,10)
oLay.AddItem('allkeys')
oLay.EndGroup()
oLay.EndRow()
oGridParam.Value.RowCount = 1
oGridParam.Value.ColumnCount = 3
oGridDataOnPSet = oGridParam.Value
oGridDataOnPSet.SetColumnLabel(0, "Command Name" )
oGridDataOnPSet.SetColumnLabel(1, "Category" )
oGridDataOnPSet.SetColumnLabel(2, "Scripting Name" )
oPPGItem = oLay.AddItem( "resultsGrid", "", c.siControlGrid )
oPPGItem.SetAttribute( "NoLabel", True  )
oLay.Language = 'Python'
sLogic='''
xsi = Application
def keyword_OnChanged():
    ppg_kw = PPG.keyword.Value
    allkeys = PPG.allkeys.Value
    cmds = Application.Commands
    kws=[]
    #get KeyWords
    if len(ppg_kw.split(" "))>1:
        kws = ppg_kw.split(" ")
    elif len(ppg_kw.split(","))>1:
        kws = ppg_kw.split(",")
    else:
        kws.append( ppg_kw )
    filteredList = []
    filteredListG = []
    filteredListS = []
    for c in cmds:
        if allkeys:
            flag = 1
            for kw in kws:
                if c.Name.lower().find(kw.lower())== -1:
                    flag = 0
            if flag == 1:
                filteredList.append( str(c.Name) )
                filteredListG.append( str(c.Category) )
                filteredListS.append( str(c.ScriptingName) )
        else:
            for kw in kws:
                if c.Name.lower().find(kw.lower())!= -1 or c.ScriptingName.lower().find(kw.lower())!= -1:
                    if str(c.Name) not in filteredList:
    PPGResults = PPG.resultsGrid.Value
    PPGResults.BeginEdit()
    PPGResults.RowCount = len(filteredList)/2
    for i in range(len(filteredList)/2):
        a = i *2
        PPGResults.SetRowValues( a/2, [filteredList[a], filteredListG[a], filteredListS[a]] ) ;
    PPGResults.EndEdit()
def allkeys_OnChanged():
    ppgkw = PPG.keyword.Value
    if ppgkw != "":
        keyword_OnChanged()
oLay.Logic = sLogic
xsi.InspectObj( oPSet, "", "", 3 )
M.Yara
gaboraa
Post by gaboraa » 02 Jun 2022, 13:57
Thank you so much for the help! Also, you are so generous myara, I'm a noob in scripting but I was able to finish my first script thanks to you guys, much appreciated!
