Change position and rotation of a deformer afterwards?
starcow
Post by starcow » 21 May 2022, 12:46
Is there a way to change the position and rotation of a deformer afterwards? So this new pose is declared as "default"? Or do I always have to redo all the weights when I notice that the position and rotation of the deformer are not yet optimal?
Many thanks!
Cheers, starcow
Re: Change position and rotation of a deformer afterwards?
Post by Mathaeus » 24 May 2022, 10:56
If it's about envelope deformer in SI, that's 'set reference pose'. Branch select skeleton, run this command through Animate>Envelope panel. For practical resaons, you want to store this new pose for later use, let's say like static action in Mixer.
Post by opoppopopp » 24 May 2022, 16:19
Or you can individually adjust the transformation values, under each deformer's static_kinematic node.
starcow
Post by starcow » 25 May 2022, 11:40
Great, that works! Thank you for the important tips!
