Hi all,
I'm having some trouble with GI. If I try to render several frames with GI, or just regions to test - it seems to leave the photon maps in memory and fill it up until XSI crashes. Is there a way to prevent this? I already checked all the boxes in preferences for "empty rendering cache", but it seems to have no effect.
I'm using 7.01
GI fills memory?
Re: GI fills memory?
What kind of graphics card are you using?
Could it be this or a similar ATI related memory leak?
wannabeArtist
This machine has NVIDIA GeForce 9400 GT, so it's not an ATI card.
But can the graphics card be related here - I mean it's the main memory of the machine that gets filled up - all 8 GB of it!
Okay, that was simply the first thing that came into my mind concerning any kind of memory leak.
I will do a more thorough search and hopefully get back to you...
edit: you're sure it's GI related. Rendering without GI doesn't cause the crash?
wannabeArtist
Thanks,
I will also post here, if I figure it out on my own.
I'm pretty sure it's related to GI, I'm working with the "fire project" and there's quite a lot of photons involved. Few frames come out ok, but the photon maps accumulate in memory and after a while it crashes.
I am not sure, however, if I have messed something up in the render configuration to cause this. It could be a user error
Does your crashes shutdown XSI immediately or do you get some kind of error message from XSI before it goes?
wannabeArtist
Well, it just freezes and gives me the hourglass (or the weird torus thing Windows uses now). After a while Windows wants to kill it, because XSI process is using something like 99% of memory.
I haven't tested rendering actual passes today, only regions, I will see if I get the same behavior later today, when I try to render a sequence.
What happens, if you try to render the scene using XSIBatch?
wannabeArtist
Thanks for the tip,
Must try that also. I actually changed to IRP in this particular (fire) project - it turned out to be much faster than with the photons and no memory problems either.
