Polygon normal angles by default
Talik
Skype: nihao00042
Post by Talik » 11 Apr 2022, 16:48
Hello. Is that possible to change the angle by which normals are calculated? Looks like by default they are 60 degree. This makes a lot of display issues and I change them to 45 degree for every single object. Cheers
Re: Polygon normal angles by default
Post by opoppopopp » 12 Apr 2022, 13:37
Isn't you Geometry Approximation (note its italic font style)a Shared property by default ?
So that you should only changed that value once per scene file.
You also can Delete that node, to make it using scene default value (became Shared property again).
Talik
Skype: nihao00042
Post by Talik » 12 Apr 2022, 14:25
Geometry Approximisation isn't a property by default. I attached that image to show what I need to be changed (as long as XSI isn't my native 3d software). Changing this value affects every object individualy not the scene.
I need normals to be calculated at 45 degrees by default.
Post by opoppopopp » 12 Apr 2022, 14:47
Every polygon in XSI comes with Geometry Approximisation node (Display nodes etc.) by default.
Click it, select YES, to make it "LOCAL", to modify its parameter individually.
or select NO, to keep it "Shared", so that you change will be global, and affect all polygon in the scene file.
Talik
Skype: nihao00042
Post by Talik » 12 Apr 2022, 14:57
That was hellpful :-bd
Post by opoppopopp » 12 Apr 2022, 15:05
Don't forget, simply delete that node will make it Shared again(e.g. sometimes imported polygon already has LOCAL version of that node)
XSI has a LOT of these kind of streamlined features
Instead of redundant buttons on GUI. "make xxx local/global" ;)
Talik
Skype: nihao00042
Post by Talik » 23 Jul 2023, 18:21
Is it possible to make Geometry Approximisation 45 degrees for all new scenes? Because I don't need 60 degrees and I change it manualy every new project
Post by opoppopopp » 23 Jul 2023, 18:43
Again, a custom event on "siOnBeginSceneOpen" will do that.
Or make a button on self, as you already known how to do that, to change it in one click.
But I have to say, change one value per scene, is not that hard.
