Hi guys,
I'm kinda rusty in Sitoa. Need to create some shader using Gradient with the properties of the "standard_surface" , but i can't get it to work.
Does someone knows how to create a gradient shader(without ICE) with the nodes from Sitoa?
Like the ramp in Maya?
Gradient in Sitoa 7.0
Surface_VR
Re: Gradient in Sitoa 7.0
It's a little late for that now.
Is it not possible to simply insert a gradient in the colors?
Just like inserting a gradient into a phong.
https://arnoldsupport.com/2014/08/28/mt ... tor-state/
Tenshi
Thanks for the idea! Sitoa 7.0 use other type of nodes, different from the example in the link.Surface_VR wrote: 13 Mar 2022, 02:29 It's a little late for that now.
I've been trying everything, hooking up all nodes but with no solution, i'm doing it really wrong i think, not good with shaders.
Edit: Gotcha! What a dumb boy i am, i was connecting it to the base... AND that i need to create some UV's for the object itself. Still the other method "Distance between shading with Vector State" could be achieved without Uv's?
Surface_VR
I don't have Arnold so I don't know the details.
If you follow the pictures, I think you can do without the UV.
Does it not reflect changes in gradient type like when you apply a gradient in Mental Ray?
Hmmm... I don't know myself...
