like this
https://www.youtube.com/watch?v=P_7aBZf4eYs
https://www.youtube.com/watch?v=vueoe8yoo0c
Fast way to create edge or surface damage in SI?
talent103
Re: Fast way to create edge or surface damage in SI?
I was going to be smart and say just do it in maya and import to XSI but it would be nice to have this in XSI natively. It seems the MAX plugin is more sturdy as the maya one just works on low poly meshes according to the plugin website.
anyheart
I do it in MAX now,but i want to keep the mesh topology in SI same like MAX as possible, don't want to export it use FBX(triangle),if don't use the triangle,the topology(some N-gon) can't maintained in SI, need to fix the holetalent103 wrote: 11 Mar 2020, 17:04 I was going to be smart and say just do it in maya and import to XSI but it would be nice to have this in XSI natively. It seems the MAX plugin is more sturdy as the maya one just works on low poly meshes according to the plugin website.
gaboraa
You can use Rock generator, it has an option to use the source geometry
Also for the edge wearing, there is a mental ray shader for this task. You can also combine it with edge corner shader too. In order to save convert the edge wear to geometry, you should use something to write it out like this: http://www.andynicholas.com/?p=57
Rock gen: https://www.si-community.com/forum/v ... =19&t=1962
Edge shader: https://www.si-community.com/forum/v ... =27&t=3556
anyheart
Thanks guys!
Rock Generator is good,i make some detail on the mesh,and then reduce the polygon can also have a good result.
