S-Remesher
S-Remesher
Post by Shekn » 24 Nov 2019, 17:06
Small addon for remeshing polygon objects in Softimage. Download here: https://ssoftadd.github.io/sRemesherPage.html
Implement two algorithms for generating quad meshes: Instant Meshes and QuadriFlow.
Re: S-Remesher
Post by rray » 24 Nov 2019, 20:33
NIce one. That's something I'll use. Thanks!
Re: S-Remesher
Post by Hirazi Blue » 24 Nov 2019, 21:07
Wow! Thanks! :-bd
gaboraa
Re: S-Remesher
Post by gaboraa » 25 Nov 2019, 07:01
Awesome!
Re: S-Remesher
Post by wireframex » 25 Nov 2019, 07:34
Thank you so much for all your work ! :ymapplause:
Kolya
Re: S-Remesher
Post by Kolya » 25 Nov 2019, 15:37
I'm getting an error "Library not found". XSI 64-bit.
Does it need any external library installed or what can be the problem?
Re: S-Remesher
Post by Hirazi Blue » 25 Nov 2019, 16:33
You're probably missing a Visual C++ redistributable... Not sure, which one, but judging from other plugins by Shekn I am assuming it's the "Visual C++ Redistributable for Visual Studio 2015 package"
Grubber
Re: S-Remesher
Post by Grubber » 25 Nov 2019, 19:40
Hirazi Blue wrote: 25 Nov 2019, 16:33 You're probably missing a Visual C++ redistributable... Not sure, which one, but judging from other plugins by Shekn I am assuming it's the "Visual C++ Redistributable for Visual Studio 2015 package"
I am having the same issue as Kolya, and, sadly, reinstalling Visual C++ Redistributable didn't help. Any other ideas what might be causing this?
Re: S-Remesher
Post by Hirazi Blue » 25 Nov 2019, 19:57
That's too bad... :-??
What does the log-window say?
Hopefully Shekn can clear up this mystery... :ympray:
Re: S-Remesher
Post by wireframex » 25 Nov 2019, 22:21
It works here perfectly
I will check tomorrow what library is used
Re: S-Remesher
Post by Shekn » 26 Nov 2019, 09:30
I am sorry, that I did not accurate check all required libraries. S-Remesher needs vc14 runtime and tbb.dll library. This dll-file can be download from the link: https://ssoftadd.github.io/download/tbb.dll and it should be placed to the same folder as SRemesher.dll.
Grubber
Re: S-Remesher
Post by Grubber » 26 Nov 2019, 09:42
Shekn wrote: 26 Nov 2019, 09:30 I am sorry, that I did not accurate check all required libraries. S-Remesher needs vc14 runtime and tbb.dll library. This dll-file can be download from the link: https://ssoftadd.github.io/download/tbb.dll and it should be placed to the same folder as SRemesher.dll.
It works! Thanks a lot! ^:)^
Re: S-Remesher
Post by wireframex » 26 Nov 2019, 14:11
Too late for me :)
Botan
Re: S-Remesher
Post by Botan » 29 Jul 2021, 08:18
that's a lot of time passed by but... there is another version of that plugin - Quad Remesher (https://ssoftadd.github.io/quadRemeshPage.html). I tried that and it seems to be broken - after clicking Remesh button something happening, plugin creates fbx file in its folder, but after that stops and nothing happens in XSI. I know the author is visiting forum, please give me an advice - is it my fault or plug is not completed?
kowy
Re: S-Remesher
Post by kowy » 01 Aug 2021, 04:04
it works
check u'r project folder/models/QuadRemesher Store/ -> fbx extensions
Re: S-Remesher
Post by Shekn » 01 Aug 2021, 05:40
It turned out that the distributive did not contain one dll-file. I added it and update the distributive. Now it should works at any system.
