Is there a way to export linear curves to an ASCII format?
Neither FBX, Collade, dotXSI export the curves data. Only a null object can be seen at the location of the curve container.
Although I can export them with the Softimage format emdl, the format is not readable for me.
I use Softimage 2010.
Cheers, starcow
Linear Curve Export?
starcow
Re: Linear Curve Export?
I could solve the problem.
If you do not go over the Crosswalk option, but export the model directly as dotXSI in version 3.6, it works.
Either a bug in the crosswalk module or a bug in the newer dotXSI versions.
Cheers, starcow
Cheers, starcow
