Hi
Is there a solution to denoise inside SI --> FxTree ?
Maybe a script to use Open Image Denoise from Intel --> https://openimagedenoise.github.io
I'm not a coder but maybe someone here can do it ?
Phil
Image denoising for SI ?
xsisoft
Re: Image denoising for SI ?
"Is there a solution to denoise inside SI --> FxTree ?"
there is a standard node- Grain-Video Noise Removal
Thanks a lot guys !
And a very special one to Shekn
Have you done it special for me ?
All the best
Phil
All the best
Phil
Not special for you, but your request was motivation for this job. It will be great if this addon would be useful. If you fail with installing it - write here, I will try to decide why it happens.
mattmos
That's amazing, thank you very much for sharing!
FX Denoising node update 1.1. Download here: https://ssoftadd.github.io/fxDenoisePage.html
What's new:
1. Compile with the latest version of the OpenImageDenoise
2. Add possibility to use two additional images (with albedo and normal) for more accurate denoising
3. Support of a custom weights data for denoising neural network. How to generate this data is explain on the GitHub page (https://github.com/OpenImageDenoise/oidn). I never try to do it. But this repository contains some example files on the weights folder. As I understand, there is on reason to use these files, because all these wights are included into addon dll. That's why this addon is so large (nearly 40 mb).
What's new:
Wow
You have done it really fast
Thanks a lot
Phil
Thanks a lot
Phil
yes, he did it, and I use it a lot!
Yep it is a very good tool. I asked him to update it because of new OpenImage
And he released it in few hours
