I never use supra mode or sticky keys, but lately using a lot pivot and snap I accidentally enter supra mode and snap get sticked.
How can I exit this mode ? And, if possible disable this feature completely.
Exit and disable Supra and Sticky mode
myara
M.Yara
Re: Exit and disable Supra and Sticky mode
Supra is needing to hold down a key while using a tool.
Sticky Keys when you press and release the key and the tool "sticks", i.e. continues to be active.
You can customize Sticky keys in the General/Interaction user preferences.
It's probably due to a bug in XSI's keyboard event handling. If you don't use sticky, everything works well if you do it like this for example:
* press and hold n (create polygon)
* press and hold s (navigate)
* release s
* release n
but if you release s and n in the opposite order, you'll be stuck in create polygon mode because of that bug.
I worked around it by using this autohotkey script that sends an 2X"escape" whenever you release certain keys.
Note the navigation hotkey itself is not in the list because I want to be able to navigate during a create polygon for example
* release s
* release n
#IfWinActive,Autodesk Softimage
; tools: reset to nil tool on exiting
; move tool
m::Send {m down}
m up::
Send {m up}
ControlGetFocus, ctrlFocusName
if SubStr(ctrlFocusName, 1, 4) <> "Edit"
Send {ESC}
Send {ESC}
return
; create polygon tool
n::Send {n down}
n up::
Send {n up}
Send {ESC}
Send {ESC}
return
;;; ADD MORE TOOLS/KEYS HERE ;;;
myara
It isn't really my problem but I've been able to replicate it in Softimage 2013.
After working with translate, scale, change pivot and snap. Some of these tools get locked.
I was doing some tests and my translate tool and snap got locked. I was assuming that holding the pivot and snap key would have locked it into Supra mode, but I couldn't get out of it so I'm not sure if it's a feature or a bug.
If I change to select mode, XSI automatically goes back to the translate tool. If I press M key to move, it goes back to translate.
If I change to move pivot, it keeps snapping to points.
I haven't been able to quit this mode without restarting XSI.
M.Yara
it looks like the transform tools are always in "sticky key toggle" mode even if that mode is off.
So if you press translate hotkey very shortly it sticks. Could be another bug (?)
But you can avoid it by setting sticky key delay to 0
And you can always hit escape to exit the current tool (sometimes you have to hit it multiple times)
myara
Thanks I’ll try with the delay option.
M.Yara
