FXDude wrote: 09 Mar 2019, 05:25
Shouldn't tablet support be turned OFF (=0) ? And isnt =1 equals ON?
Also do you use a wacom by the way?
indeed ENABLES tablet pressure support, which Softimage disables by default (look
here)
I found an ancient solution to disable Wacom usage in Softimage via the Wayback Machine,
but I don't know if it still applies (USE AT OWN RISK!): you can read it
here.
(The author is former Softimage developer Luc-Eric Rousseau...)
is a workaround for certain problems with selection (still not mentioned
here!!!).
It can, however, be found in the "Softimage 2015 Readme" under "Known Issue" "SOFT-9444"
here.
Look at
this thread. The corresponding Mailing List thread starts with
this post.
