need your knowledge! which addons from http://www.si-community.com/community/resources.php work correctly from 2015
xsisoft
need your knowledge! which addons from resources.php work correctly from softimage 2015
Re: need your knowledge! which addons from http://www.si-community.com/community/resources.php work correctly from 201
As a general rule you can assume most of them will work with Softimage 2015.
It's hard to tell which, I would advise you to simply try...
Or ask here for specific ones you'd like to use.
xsisoft
thank!
I would like to download all the add-ons and test,
Is there a way to download FTP? or something like all add-ons at the same time — not pumping out one addition at a time (I tried to download the whole site, but the directory with additions is not downloaded)
This is probably a question for the author of the site.
Yes most (hopefully all) of them work with the latest version unless they have the "win32" tag. If you use Linux then the ones with the "win..." tags won't work either.
There's an offline version from 2 years ago:
https://www.si-community.com/forum/ ... 41&p=56464
But I wouldn't recommend testing all of them, you'll be busy for a month at least doing that.
myara
The only problem I could see it would be if some addons are using pyside and you are using Windows 10. In that case you would need to use an external Python, and edit the setenv file.
Other than that, all the plugins should work in the latest Softimage version.
M.Yara
xsisoft
thank you so much!
Windows- is not Windows 10 , Windows 7 for compatibility
xsisoft
dear rray, I correctly understand that you can only download the offline version,- 2 years ago,- there is a site + add-ons, or just add-ons?
Is it possible to create offline only add-ons - not 2 years ago, but today?
Stuff would be quite hard to find without the index (files are quite jumbled and grouped in folders by author nicknames)
also some of the huge files that would bloat the zip to >10gb would be missing
I see if I can do it this week, I'll post it here in case.
xsisoft
Rray, thank you personally for this site!
and all of us have a unifying love for softimage - the most friendly 3D package for 3D creators!
xsisoft
The archive only with the add-on is very useful - expands the possibilities of the program.
if it is possible to catalog automatically, by topics (rendering, modeling, ...) and not by the authors' pseudonyms, it would be excellent!
no prob
zipped the resources folder http://traypen.com/bb/xsi_rsrc_feb_18.zip .. (2.4 gb)
but still sorted by nicknames, no idea how it would be possible to automatically organize the addons by tags
At some point later I might create a big index html for from the resource section for local access.
This would have working links to the local files and would be searchable then for tags etc...
xsisoft
Respect Rray!
downloaded the archive
and 312 author folders, 1092 results found
Is it possible to create a local copy of the site -but only with the resources section ??? (resources.php)
then having an archive-folder with additions http://traypen.com/bb/xsi_rsrc_feb_18.zip (thank you so much for making it)
and a local copy of the -resources section which you can use as an offline search!
you probably about the same
"At some point later I might create a big index html for from the resource section for local access.
This would have working links to the local files and would be searchable then for tags etc..."
